dogon dory
Vessel Name: DogOnDory
Posted: Mon May 02, 2005 1:01 am Post subject: Survey: problems with fuel tank holddown system |
Posted: Mon May 02, 2005 5:18 am Post subject: |
Dan-
When I bought my "87 Cruiser used in "98, both the starboard tank's forward cleats were loose. I cleaned out the holes and some very minor rot, filled the spaces with Marinetex epoxy, and jammed oversize sheet metal style stainless screws in the holes, using the hydraulic pressure of the screws to push the wet epoxy into the spaces. No problems after 7 years. None of the other cleats has ever loosened up. Good survey idea. Joe. _________________ Sea Wolf, C-Brat #31
![](http://www.c-brats.com/albums/SeaWolf/zzseamuspadraigobaiogheallainmi_narach0634_thumb_001.thumb.gif) ![](http://www.c-brats.com/albums/SeaWolf/images_3.thumb.jpg)
Joined: 02 Nov 2003 Posts: 8555 City/Region: Birch Bay, WA
Posted: Mon May 02, 2005 9:30 am Post subject: |
We either did not have any problems, or were not aware of them, for the two years we owned our CD22... _________________
CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Mon May 02, 2005 4:49 pm Post subject: |
1. Yes
2.2002
3.2004
4.Front and side starboard tank- no problem on the port tank.
5.Minor softening of the balsa about 3/4" dia around pulled screws. _________________ Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas |
flagold
Joined: 23 Mar 2004 Posts: 951 City/Region: Abbeville
State or Province: AL
Vessel Name: C-Dawg-E
Posted: Mon May 02, 2005 6:34 pm Post subject: |
1. Yes
2. 2003
3. 2003
4. Screws loosened, tanks bulged, no rot, sealed and re-installed screws. |
Mr. Fisherman
Vessel Name: Sea Lion
Photos: Sea Lion
Posted: Tue May 03, 2005 12:43 am Post subject: |
Yes,
1995
2004
Both
welded new supports to the tank and lagscrewed them into the deck and sealed with 5200. Some have pulled out and I need to come up with a better repair. _________________
Live to Fish
Fish to Live |
C-Sick
C-Dory Model: R-25 Tug
Vessel Name: Gratitude
Photos: C-Sick
Posted: Fri Jul 22, 2005 2:02 am Post subject: Add Another 2003 |
I just noticed on my return trip from Blakely that my Port Side front chalk is pulling out. I will have to explore the damage that might be done.
2003 22ft Cruiser _________________ C-Sick
In A Bad Way |
Mr. Fisherman
Photos: Sea Lion
Posted: Fri Jul 22, 2005 2:09 am Post subject: |
1. Have you had a problem with the screws pulling out that hold the cleats/chocks in place around the fuel tanks? Yep. A 58 gallon tank held in place by 6 #8 screws was just plain crazy.
2. When was the boat built? 1995
3. If you've had the problem when did it show up? While I was out halibut fishing last year.
3. Which chocks came loose? Front, sides or both. One tank or both? Screws pulled out on the Port side then the weld on the tank support started to tear.
4. Have you noticed any rot in the holes that the screws backed out of? Nope, I filled them in with 5200. |
