Susuki Tilt Limiter Cam
Robbi
City/Region: Chambers Bay
C-Dory Year: 2023
Photos: C-Run
PostPosted: Fri Nov 16, 2007 10:54 pm    Post subject: Susuki Tilt Limiter Cam Reply with quote
Suzuki Tilt Limiter Cam.....
Just a FYI:
After boating on Tuesday evening, I came into my boathouse and tied up the boat. When I tried to raise the engine, nothing. I used both of the trim buttons, the one on the engine and the one on the control handle. It would go down, but it would not come up. A bit of panic on my part because the tide was going out and my boat goes dry on low tides. It was now dark, the wind was up, and no where to go. Long story short. If the tilt limiter cam (the black plastic ring around the swivel bracket in the picture) moves to the full up position, the motor will not raise. The feature is designed to limit the tilt of the engine in case the engine hits the motor well in the full up position. Who would guess that it could limit ANY upward movement of the engine? I talked to three outboard mechanics, and they all thought the problem was in a relay. The forth mentioned the limiter cam right off. I rotated it downward, and the motor lifted up, much to my relief. I am not sure what moved the cam. I suspect the control cables may come into contact with the cam at some point, or it may have vibrated enough to move. Don't know for sure, but now I know how fix the problem. Robbi
2023 C-Dory 23 Venture Sport
2003 C-Dory 19
sold 2019
2004 C-Dory 16 Cruiser
Sold 8/2015
2004 C-Dory 19 "C-Run"
Sold 8/2011
1989 C-Dory 16 Angler
Sold 2010
dogon dory
Vessel Name: DogOnDory
PostPosted: Fri Nov 16, 2007 11:16 pm    Post subject: Reply with quote
Alok
City/Region: League City
State or Province: TX
Photos: Top Cat
PostPosted: Fri Nov 16, 2007 11:39 pm    Post subject: Reply with quote
Another situation with the Suzuki cams- if they are adjusted differently, the motors in a two engine boat will rise to different heights in the fully "up" position. Drove me nuts until I figured it out.
Alok
C-Dory Tomcat (Topcat) sold January 2012
timflan
Photos: Two Lucky Fish
PostPosted: Sat Nov 17, 2007 2:38 am    Post subject: Reply with quote
And another thing...if you adjust it so the engine lifts up just barely far enough for the tilt support lever to engage, DO NOT drop the engine onto the tilt support lever, because the tilt limiter cam will prevent you from lifting the engine OFF the tilt support lever. It won't move at all. So then ya gotta reach under there and readjust the cam, so you might as well not have adjusted it in the first place.
In my case, it's pretty difficult to find a spot that allows the full range of movement I need to engage the tilt support lever AND prevents the hydraulics from straining when the full range of motion has been reached.
I have a Suzuki-manufactured, Johnson-branded 90 hp engine from 2005.
Timothy R. R. Flanagan
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sun May 01, 2011 3:51 pm    Post subject: Port engine Reply with quote
Hi gentlemen,
Sorry to ping an old thread but today I splashed Napoleon and my port engine will not trim all the way up. It goes up and down fine to this point then stops. My starboard engine goes all the way up as usual.
Where do I find the mechanism that regulates the trim level? I've never touched it on purpose but want to start there.
Thanks!
Captain Matt
PostPosted: Sun May 01, 2011 7:43 pm    Post subject: Reply with quote
the main cause of the problem is salt crust build up around the cam limit switch. you have to spray with fresh water around the switch which is under the motor body inside of the motor mount. you cant see it unless the motor is up on most boats. and you cant get the motor up unless its clean.
Robbi
C-Dory Year: 2023
Photos: C-Run
PostPosted: Sun May 01, 2011 7:58 pm    Post subject: Reply with quote
The trim limited cam on my 90 is located right
Below the bracket where the steering arm is
Attached, in the center of swivel bracket. It is a black
Plastic ring that is in the center of the bracket.
I will try and post a picture.
Robbi
[/img]
Robbi
C-Dory Year: 2023
Photos: C-Run
PostPosted: Sun May 01, 2011 11:54 pm    Post subject: Reply with quote
Here is a picture of the trim limiter cam on my 2004 Suzuki 90. It is located on the front of the engine and this picture was taken with the engine in the full down position. The steering arm is directly above, surrounded by all of the necessary grease. Embarassed
You can change the tilt by rotating the black plastic ring on the cam.
Robbi
Robbi
C-Dory Year: 2023
Photos: C-Run
PostPosted: Mon May 02, 2011 9:40 am    Post subject: Reply with quote
Oops! Try again.
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Mon May 02, 2011 10:04 am    Post subject: Tilt Reply with quote
Thanks for the replies. Perhaps I accidentally bumped it when installing the new steering system this winter. I will check it out again today. My shop manual has a picture but it's very small.
PostPosted: Mon May 02, 2011 11:55 am    Post subject: Reply with quote
I had the same type of problem on my 2005 Yamaha 90. The ring with the cam is plastic and actually broke. It was somewhat difficult to replace, so I just wired it together with stainless steel wire. Hasn't failed yet! (This is the only problem I've had with the Yamaha in 6 years!)
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Mon May 02, 2011 7:37 pm    Post subject: Found it Reply with quote
Thanks for the replies. It can very easily be bumped and I must have done it when installing the new steering system.
It is a small plastic piece that rotates very easily - like turning the knob on a car stereo. Took 2 seconds once I knew what to look for and voila - lifts to the usual spot.
timflan
PostPosted: Fri May 06, 2011 5:07 pm    Post subject: Reply with quote
One other thing: Make sure you get it adjusted so the trim/tilt hydraulics STOP PUSHING before it reaches the mechanical limit of the engine's travel, whatever that happens to be. It can put a lot of torque on things if it's still pushing when there ain't no place left to go!
Page generation time: 0.1619s (PHP: 19% - SQL: 81%) - SQL queries: 30 - GZIP disabled - Debug on
