correct height for outboards while traveling
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Wed Apr 27, 2011 9:54 am    Post subject: Reply with quote
I use a 3/4 inch dowel like Bill and El. I've found if I put it in the notch in the Yamaha mount and wedge it, the motor may be a tad low for some gas stations etc and speed bumps. I've lately found I can put the dowel a few inches up from the notch and secure with a bungy and drop the motor till it's wedged and it stays nice and secure mostly in the down position. my mechanic concurs by saying, "it's down when you're cruising the sea isn't it?' should be ok to trailer that way. George
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Wed Apr 27, 2011 10:39 am    Post subject: amazing set of replies Reply with quote
It is just amazing to me the variation in the replies to this topic. Even the mechanics we use aren't in agreement. So I guess the answer is, if what you've been doing works, then keep doing the same thing. It sounds like no one has had a transom problem no matter what they've done with their engine position. Its great when everyone is right! I wish all topics taken up by the human race could come out with the same result.
Testosterone Tales-Amazon.com
KG7RC
PostPosted: Wed Apr 27, 2011 12:26 pm    Post subject: Reply with quote
BrentB wrote:
This company has a wedge support
http://www.m-ywedge.com/
Just a word of caution if you use this wedge. Be VERY CAREFUL if you have them in place that you don't forget they are there and try to tilt the engines down. They are very hard rubber and will destroy the tops of the T/T reservoirs. Angry I did this very thing last fall (it's on another thread) and ended up with about $500 in repair work (not sure yet, have not gotten the bill). With the engines linked together, I got both engines at the same time!! Not the fault of the device but mine. In order to replace the tops of the reservoirs, the engine mount on the RHS has to be removed (while supporting the engine to get to the T/T mechanism.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Wed Apr 27, 2011 12:32 pm    Post subject: Reply with quote
Evinrude had an intermediate trailer position support on their V-4 and up motors that is pretty nice.
I'm in agreement that the motor tilted up shifts weight forward on the transom, and so don't see any extra leverage being an issue. But, whatever makes an owner most comfortable, there really is no "wrong" answer here.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Page generation time: 0.0336s (PHP: 62% - SQL: 38%) - SQL queries: 21 - GZIP disabled - Debug on
