Trailer Light Indicators
damason
City/Region: Valparaiso, Florida
Photos: CHARITY
PostPosted: Sun Mar 06, 2011 8:27 pm    Post subject: Trailer Light Indicators Reply with quote
Sometimes when trailering my C-Dory 25 a friend following me later says that my trailer lights are not working. Crying or Very sad This really concerns me as I want my lights to be working all the time. In the day time there is no way to tell if they are working or not. At night all I can see is the clearance lights.
I came up with an idea: Install LED lights on the trailer fenders to show the running lights, stop lights, turning signals, and emergency flashers. I bought the yellow/orange LED lights from Radio Shack. They have a 90 degree display angle and are pointed straight forward. They also help as clearance lights. I wired them into the trailer wires at the front of the trailer. I used heat shrink fittings to keep out water and corrosion.
LED Light Package data
LED Light and receipt showing cost of $1.99 per LED light
Installation of LED lights
Looking in the rear view mirrors
When trailering day or night I can visually check my trailer lights anytime by looking back. The outboard LED light is a running light and the inboard LED light is the stop light, turning signal, and emergency flasher. Laughing
Marlene and Dave Mason
Once a C-Brat - Always a C-Brat!
smittypaddler
City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
PostPosted: Mon Mar 07, 2011 10:58 am    Post subject: What a good idea Reply with quote
That'll be my summer project. It's annoying, having to run around the trailer to check lights, and I have a certain length 2x4 to press the brake pedal, all of which can be avoided!
PostPosted: Mon Mar 07, 2011 11:17 am    Post subject: Reply with quote
So I assume these are wired in parallel to the lights. If so, this will indicate that the connection to the trailer wiring is solid but won't indicate that the lights are working. To do the latter, you would need something in series with the lights so that when a light filament is open (or a wire is open someplace in the circuit) OR something in parallel that only lights when there isn't a voltage drop across the filament. Then you would know when the lights are not working. VW does this somehow on their newer vehicles such that an indicator light comes on when there is an open in any light (they the owner has to figure out which light isn't working).
PostPosted: Mon Mar 07, 2011 11:54 am    Post subject: Reply with quote
Roger, one old Volvos had a dash light that did that. Sometimes hard to figure out which light was out...
And with those lights on the trailer, you may need indicator lights to tell you if the indicator lights are working. Shocked
I think I'll just stop and check. If it's a turn signal that's out, you may get a "fast" blink on your dash indicator. If it's a brake light, the same may happen if you put the hazard flashers on. If it's the tail or running lights, you can see that on the trailer.
Lots of ways to kill that bird.
Neat idea though! Thumbs Up
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Mar 07, 2011 12:46 pm    Post subject: Reply with quote
AN easy wy to check trailer lights is to turn on the headlights and the emergency flashers. Walk around the trailer, and every light should be working. The emergency flashers activate the same lights as the turn signals and brake lights.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
PostPosted: Mon Mar 07, 2011 2:28 pm    Post subject: Reply with quote
That "walk around" Matt suggested is important, especially for us older folks. You'd be surprised at what was forgotten: safety chain, lights, ladder, antenna up. And remember the favorite of the CHP: the break away wire. The walk around is one thing I try to remember.
After working with indicator lights for years, I think that they only show that the indicator light is working.
Jeff & Mimi
City/Region: Vancouver
Vessel Name: Kristen Rose
Photos: Kristen Rose
PostPosted: Mon Mar 07, 2011 2:54 pm    Post subject: Reply with quote
Amen...
there is a awful lot there of stuff that us old folk's have to remember and it get's awful expensive really fast if we don't. I hope everyone is having a super day.
Jeff, 1987 C-Dory 22FT. Angler The Kristen Rose
PostPosted: Mon Mar 07, 2011 3:34 pm    Post subject: Reply with quote
We tow a Honda Pilot behind our RV at least 10,000 miles every year, plus towing boat trailers. We stop every two hours and do the "walk around"--also before we start off. Included in this is having the flashers on--which will indicate of brake and turn lights are working.-temp of tires, hubs and brakes, as well as checking the running great and hitch.
damason
Photos: CHARITY
PostPosted: Mon Mar 07, 2011 7:07 pm    Post subject: Trailer Light Indicators Reply with quote
YES! I agree that you can tell that the trailer lights are working by doing a walk around. I do a walk around and check the lights when first hooking up the trailer to the tow vehicle. I also stop every hour or so and do a walk around to check that the lights are working.
However I cannot do a walk around while driving 60 miles a hour down the road. The Trailer Light Indicators are to give you a warm fuzzy feeling that they are still working while driving.
They are hooked up parallel to the trailer lights.
I hope this idea helps some of you C-Brats that would like this feature on your trailer.
smittypaddler
PostPosted: Mon Mar 07, 2011 10:30 pm    Post subject: My electrician shop class was over 50 years ago Reply with quote
It's been a long time since I took shop in high school, but wouldn't the circuit below let the led indicator be lit only when the trailer light is working? The led light and resistor are in parallel, and that parallel circuit is in series with the trailer light. The resister in parallel with the led means the led only gets the .001 amp (for example) it needs.
.........I--.001 amp led-------I
neg---I..............................I---trailer light---pos
.........I--.001 ohm resistor--I
This is after edit: I had trouble with spacing (this must be variable size font), in my drawing, so I've added periods (.) to make things align. Hope that makes it look like I want it to. Just pretend the periods are spaces, and the hyphens and I's are wires. This gets more confusing the more I try to fix it.
Oops, that should've been ohm instead of amp on the resistor.
damason
Photos: CHARITY
PostPosted: Tue Mar 08, 2011 9:31 am    Post subject: Reply with quote
Na Waga. Thanks for the info. Draw a schematic of the circuit and scan it into a picture on your computer or take a picture with your digital camera. Transfer the ditital camera picture to your computer. Include the picture of the circuit in your post. You will need to put the picture into your C-Brats Picture Album. If you do not have a Picture Album ask the C-Brats administrator to make one for you. Then this schematic will be very clear to all readers of this Forum.
I have worked many years in electronics and understand your circuit, however there are many people that do not know ohms from apples. Thanks again.
smittypaddler
PostPosted: Tue Mar 08, 2011 11:14 am    Post subject: Here's a picture Reply with quote
Here's a picture, I hope:
Fun, doing this with the GIMP (Graphic Image Manipulation Program).
tomherrick
Guest
PostPosted: Tue Mar 08, 2011 11:55 am    Post subject: Reply with quote
Nice solution, Dave.
damason
Photos: CHARITY
PostPosted: Tue Mar 08, 2011 6:47 pm    Post subject: Trailer Light Indicator Reply with quote
Thanks - Na Waga. Very good schematic.
PostPosted: Wed Mar 09, 2011 2:35 am    Post subject: Reply with quote
"It's been a long time since I took shop in high school, but wouldn't the circuit below let the led indicator be lit only when the trailer light is working? The led light and resistor are in parallel, and that parallel circuit is in series with the trailer light. The resister in parallel with the led means the led only gets the .001 amp (for example) it needs."
So, does this mean that the indicator only comes on IF the light is actually on too. So if the trailer light bulb burns out, the indicator light will not be on? COOL, if it works that way.
Sure looks nice either way though.
Page generation time: 0.0463s (PHP: 68% - SQL: 32%) - SQL queries: 31 - GZIP disabled - Debug on
