Fuel Selector Replacement
Peter_BDA
City/Region: Bermuda
C-Dory Model: 22 Classic
Photos: Luna-Sea
PostPosted: Thu Feb 10, 2011 2:10 pm    Post subject: Fuel Selector Replacement Reply with quote
Hey all,
Looking to replace my fuel selector switch and SOMEWHERE on the site here is a picture (which I, of course can't find now!!) showing a set up done by a rigger with 3 lever handle switches/valves. Does it ring a bell with anyone?
Also welcome any advice on the subject!
Thanks!
Peter
Peter Aldrich
Bermuda
Tim & Dave Kinghorn
City/Region: El Dorado Hills
Vessel Name: Sound Venture
Photos: Sound Venture
PostPosted: Thu Feb 10, 2011 5:26 pm    Post subject: Fuel Selection Module Reply with quote
In our photo album is a picture of our fuel switching module.
It probably isn't what you were looking for, but you might look at our photos to give you some ideas for your boat.
We wanted to be able to switch fuel tanks as well as direct the fuel to the main engine, the kicker, both main and kicker, an auxilliary line (to run gas to another source), or a vacuum gauge to check fuel line pressure.
We put the switching handles inside the port lazaret for protection as well as security. However, you could just as easily mount them outside.
Tim and Dave Kinghorn
Don't let the fear of tomorrow steal from the pleasure of today.
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Thu Feb 10, 2011 5:36 pm    Post subject: Reply with quote
Maybe this is it. If so, it's in Doryman's album.
Peter_BDA
Photos: Luna-Sea
PostPosted: Thu Feb 10, 2011 5:59 pm    Post subject: Reply with quote
Rob and Karen thank you! This is the photo I saw!
Many thanks!
Peter
Les Lampman
Dealer
City/Region: Whidbey Island
PostPosted: Fri Feb 11, 2011 2:57 pm    Post subject: Reply with quote
Peter,
I've done several fuel selector systems like the one shown in the photo above. And while the installation was done neatly I will point out that the 180-degree turn at the top (2 90's) is very much less than ideal. If at all possible when you do yours try not to get radical turns introduced into the system.
The idea in simple form is to have a shut-off valve in each of the two fuel lines from the tanks and then to have one "cross-over" valve.
Just for further explanation...
Each of the two inline valves (in the lines from the tanks) are essentially selector valves for that particular tank. That is, they're they gatekeepers and they specifically determine whether any fuel leaves their attendant tank.
The cross-over valve is just that, it let's fuel cross-over from one tank to the engine on the opposite side (note that 3 valves are not necessary for a single engine boat).
- If you close both inline valves no fuel flows (regardless of how the crossover valve is positioned).
- If you open both inline valves, and the crossover is closed, each tank feeds one its own engine.
- If you close one inline valve and open the crossover, both engines will be feed by the tank with the open inline valve.
- If you open both inline valves and open the crossover almost all the fuel is supplied by each tank to its own engine...the crossover having very little impact on things.
Les
www.marinautboats.com
Page generation time: 0.0293s (PHP: 60% - SQL: 40%) - SQL queries: 22 - GZIP disabled - Debug on
