milky oil
TomCaz
City/Region: Edgewater
State or Province: MD
PostPosted: Fri Oct 15, 2010 7:06 pm    Post subject: milky oil Reply with quote
The crank case oil is milky, I noticed a slight milky color and changed the oil and over the past few outings the oil continues to get milky but at a faster rate.
The power does not seem to be lacking, Is this a major $$$$$$$$$$$$$$$$ repair or worse?
TomCaz
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery"
Winston Churchill
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Oct 15, 2010 7:16 pm    Post subject: Reply with quote
For cars, the head gaskets are bad.
Brent Barrett
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Fri Oct 15, 2010 7:32 pm    Post subject: Reply with quote
I imagine that you know that a milkyness in oil means water in your oil. Not good get it checked out at the soonest.
Chuck
Bootleg Hooch
PostPosted: Fri Oct 15, 2010 7:58 pm    Post subject: Reply with quote
It does sound like water getting into the system and that probably means a gasket or seal is broken somewhere in the system. Could be a head gasket, could be a number of other seals depending on make and model. Regardless of the cost to find and fix the problem, it will not get any cheaper the longer you run it with this problem especially if you are introducing salt water into the inside of the engine. You should seek fairly immediate help if your running in salt water.
TomCaz
PostPosted: Fri Oct 15, 2010 8:08 pm    Post subject: Reply with quote
yes, I knew it was water but do not know the point of entry. Its going in the shop asap. I thought it was odd to be taking on water in the crank case and not have any loss of power
TomCaz
Sam & C-Chickie
City/Region: Poulsbo
Vessel Name: Scout
Photos: Scout
I have a Suzuki 90 h.p. and had the same problem. Turns out it was just a bad thermostat. It was replaced and all is well... The good folks at Kitsap Marina took care of me., I wish you good luck.., Sam
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Fri Oct 15, 2010 9:23 pm    Post subject: Reply with quote
Could be just the seals in the lower unit, just replace them and see if that fixes the problem.I would also check to see if the vent/fill screws .( lower unit ). are sealing properly.I would replace them too..they are cheap.I had the same problem ...milky oil..when i had some-ones fishing line get wrapped around my propeller and messed up the seals.Tug
PostPosted: Fri Oct 15, 2010 9:29 pm    Post subject: Reply with quote
The oil in the crank case is completely separate from the lower unit. If the milky material is in the lower unit--then definately seals.
No matter what don't run the engine any more, and get it taken care of next week. I would change out the oil now, and leave the clean oil sit in the unit until it is fixed. There can be multiple causes.
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Oct 17, 2010 1:06 am    Post subject: Reply with quote
My 90 Honda did exactly that....it was the thermostat. They are cheap and an easy self repair.
Jack
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun Oct 17, 2010 1:17 pm    Post subject: Reply with quote
Jack
If it is running cold, incomplete combustion will cause milky oil. I had that issue on an 8hp Honda classic, but never (yet) on the Honda 90... The cure on the 8hp was a different thermostat, and hotter plugs.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Sun Oct 17, 2010 1:43 pm    Post subject: Reply with quote
One of our twin 40 Honda's thermostats stuck open on our 2007 Southeast Alaska cruise. Would hardly run at idle and crankcase filled with unburned gas mixed with the oil, but remember color of oil and gas to be darker if anything then normal. Bought my replacement thermostat from Les at EQ (now carry a spare in boat) and though I thought the engined might have been damaged he suggested otherwise. It now has 1336 hours on it and has run great for the last 300 hours since the thermostat stuck , so appears he was right.
Page generation time: 0.0603s (PHP: 64% - SQL: 36%) - SQL queries: 28 - GZIP disabled - Debug on
