Fuel Tank Switch
Homer22
City/Region: Homer
C-Dory Year: 1988
PostPosted: Thu Sep 23, 2010 3:35 am    Post subject: Fuel Tank Switch Reply with quote
Is there anything out there that would allow electronic switch control of the two fuel tanks from the wheel? As a replacement for the stern mounted manual switch.
sjboysen
C-Dory Factory Representative
City/Region: Bellingham
Photos: Triton Plant Photos
PostPosted: Thu Sep 23, 2010 11:26 am    Post subject: Reply with quote
Yes there is an electric fuel manifold that I have used on the Osprey, Orca and SeaSport lines from IMCO called the "Super Fuel Valve", the part number is SF-206. IMCO is out of California and their number is 800-899-8058.
This manifold is mounted at the transom and then wired directly to a switch at the main helm for easy switch over. I liked it because it also has a redundant manual function in case of electrical malfunction. It would need to be mounted on the transom however as it is approximately 10" long, but I recommend it for twin tanks as it has worked for us very well.
I hope that this information is helpful, and don't hesitate to give me a call at 360-393-3283 if you would like more information about it.
Sincerely,
Scott
Homer22
City/Region: Homer
C-Dory Year: 1988
PostPosted: Thu Sep 23, 2010 2:01 pm    Post subject: Reply with quote
Thanks much Scott. Will def look into it.
Page generation time: 0.0375s (PHP: 39% - SQL: 61%) - SQL queries: 20 - GZIP disabled - Debug on
