Big dave
Joined: 20 Aug 2005 Posts: 269 City/Region: Vancouver
Vessel Name: Raven Dancer
Photos: Raven Dancer
Posted: Tue Jun 15, 2010 4:28 pm Post subject: Salt Away |
Anyone ever use a product called "Salt Away" ? I have always flushed my motors with fresh water after use in the salt. This time the boat will be in the salt all summer and fall. Wonder if I should tilt it up and hook up the ear muffs and flush with fresh water ? Can you even run the motor when it is tilted ?
Thanks for any advise.
Dave. |
Larry Q
Joined: 17 Mar 2006 Posts: 231 City/Region: Rochester, Wa
Vessel Name: C-ya
Posted: Tue Jun 15, 2010 5:21 pm Post subject: |
Dave-
I spray the exterior of my engines and all the hardware on the boat with Salt Away after each trip but have never ran it through the engines. We have a very convenient fresh water boat launch that we stop at on the way home to flush the engines. |
Joined: 02 Nov 2003 Posts: 21469 City/Region: Pensacola
Posted: Tue Jun 15, 2010 6:29 pm Post subject: |
I have a 3 gallon pressure container I fill with a salt away solution. If I am running in salt water for some period and cannot flush, I flush out the entire system with the salt away solution about once a week. Don't run the motor tilted up. _________________ Bob Austin
Big dave
Posted: Tue Jun 15, 2010 6:54 pm Post subject: |
Bob how does the pressurized system work ? Sounds pretty interesting. My Yamaha does have the water flush adaptor built in but I'm not sure if it gets down to the lower unit pump or not.
Dave. |
Mike...
Photos: Accelerando
Posted: Tue Jun 15, 2010 7:07 pm Post subject: |
Dave, thanks for starting this thread. I have been wondering about this myself.
Our boat will be in brackish water for 5 months or so. I have been looking at Salt Away, but don't see how I would flush the outboards or even spray them down there in the slip. And I am sure there is something in my marina contract that would get me strung up if I did.
For those of you that keep your boats in brackish or salt water for great lengths of time, what do you do in this situation?
mike |
POSSUMGAS
Joined: 23 Jan 2010 Posts: 14 City/Region: virginia beach
Vessel Name: HUNKEY DORY
Photos: HUNKEY DORY
Posted: Tue Jun 15, 2010 7:38 pm Post subject: Salt Away |
I use my Honda in salt water all the time. The Chesapeake Bay. I do use the salt away adapter with the solution. I put the adapter that came with the motor. As far as HONDA 90s,I have the water pressure on low. Just enough to get a flow out the pee hole. The water does run out all of the water passages. To me, Salt away works very good. Some people pour Salt Away in the same water they use to wash the boat. |
C-Hawk
Joined: 02 Nov 2003 Posts: 2150 City/Region: Carpinteria / Channel Islands
Vessel Name: C-Hawk
Photos: C-Hawk
Posted: Tue Jun 15, 2010 9:01 pm Post subject: |
Salt-away is $$$$$- I use white vinegar, in the salt-away applicator, it works just as good for a lot less $$. _________________ Roger
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
God is Great, Beer is Good.... and People are Crazy |
PW
Joined: 21 Aug 2006 Posts: 25 City/Region: Browns Point
Vessel Name: Viking Lady
Photos: Viking Lady
Posted: Wed Jun 16, 2010 1:03 am Post subject: |
King Salmon, a local certified Honda sales/service, services the 90's on the Viking Lady and I'm told to not run the motors tipped up. The Lady stays in a covered slip 7 to 8 months a year and the motors are flushed regularly with Salt Away. I have started to use the Honda adapter which seems to being doing a good job and it's a lot easier than using muffs while in a slip. I have been told the motors should NOT be ran when flushing with the adapter and that the process does the same good job as flushing with the muffs when she is on the trailer. Flushing with the muffs when in the slip has always always been less than a dignified process - but I don't cling to the motors to graciously when they are tipped up over the water (40 years ago I may have done a little better...javascript:emoticon(' ').) Hope I'm doing it right! I might try the Vinegar approach - sounds like a good idea. _________________ Aboard the Viking Lady
Michele and Ron |
PW
Photos: Viking Lady
Posted: Wed Jun 16, 2010 1:04 am Post subject: |
King Salmon, a local certified Honda sales/service, services the 90's on the Viking Lady and I'm told to not run the motors tipped up. The Lady stays in a covered slip 7 to 8 months a year and the motors are flushed regularly with Salt Away. I have started to use the Honda adapter which seems to being doing a good job and it's a lot easier than using muffs while in a slip. I have been told the motors should NOT be ran when flushing with the adapter and that the process does the same good job as flushing with the muffs when she is on the trailer. Flushing with the muffs when in the slip has always always been less than a dignified process - but I don't cling to the motors to graciously when they are tipped up over the water (40 years ago I may have done a little better...(' ').) Hope I'm doing it right! I might try the Vinegar approach - sounds like a good idea. |
Big dave
Posted: Wed Jun 16, 2010 1:44 pm Post subject: |
I think I will try the salt-away, the vinegar is a great idea and would save a bunch of $$ and I wouldn't be surprised if salt-away is just a acid too. I like the idea that the salt away is a proven product, but on the other hand vinegar has been around for thousands of years.
I guess the best way to flush after reading the post is to just hook the hose up to the flush adaptor and let the hose run.
I will be heading up to the Broughtons as soon as grandson #3 arrives (due date 6/1 I will be spending the summer & fall on the boat, If anyone would like to join me or meet up on the water or even just follow for the trailer ride up to Port Mcneill that would be great.
Thanks for all the great responses !
Dave. |
Posted: Wed Jun 16, 2010 8:17 pm Post subject: |
The Salt Away, will not get below the water pump impeller--and may not get all of the way down the tubing from the pump. I started using it with a boat where there was a build up in the head of the engine (Yamaha 90-about 1992 vintage). It worked well for that engine--so I have used it since. |
Wefings Dealer
Joined: 29 Nov 2005 Posts: 2086 City/Region: Panhandle
Photos: Cruise Ship #4
Posted: Wed Jun 16, 2010 11:38 pm Post subject: |
When did salt cease to become water soluble ?
Marc _________________ Wefings Marine Website
Since 1909 |
Jack in Alaska
Joined: 17 Aug 2004 Posts: 1192 City/Region: Anchorage/Ninilchik
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
Posted: Thu Jun 17, 2010 2:35 am Post subject: |
I purchased a quart of West Marine version of salt away today. It costs 50% less than SaltAway and the sales person said it was the same stuff in a different jug.
Marc.............I wonder about that solubility thing also. _________________ On the HIGH TIDE-II, wife Carolyn and I.....Another summer fishing on the HIGH TIDE II in the Cook Inlet at Cape Ninilchik, Alaska.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Bare hull & trailer sold in Nov. |
Matt Gurnsey Dealer
Joined: 11 Nov 2008 Posts: 1532 City/Region: Port Orchard
Photos: Kitsap Marina
Posted: Thu Jun 17, 2010 11:53 am Post subject: |
Wefings wrote: | When did salt cease to become water soluble ?
Marc |
That made me laugh-
But we have seen engines that the salt has become packed into from either improper flushing (if any at all) and very small passages and Salt Away has cleared most of them up.
I don't think Salt Away is needed every time you flush the engine, but at the end of the season before putting the thing to bed, and good cleasning is a good thing. _________________ Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991 |
Socrateur
Vessel Name: Sea Skipper
Photos: Sea Skipper
Posted: Thu Jun 17, 2010 12:09 pm Post subject: |
Cold water is not as effective a solvent as warm or hot water. Vinegar and saltaway work better than straight water at lower temps. If one were able to flush with hot water, then salt buildup in the engine probably would not occur. _________________ Capt Jay |
