Tach problem
Dan McNally
City/Region: Bothell
Vessel Name: Shannon- Colleen
Photos: Shannon-Colleen
PostPosted: Sun May 09, 2010 10:17 am    Post subject: Tach problem Reply with quote
Hi all,
Just a question regarding the tach on a honda 90, it has worked perfectly since new but yesterday it would not give me a reading. Then about an hour in to the trip it began to register but it would not read above 3500 any ideas?
Dan
PostPosted: Sun May 09, 2010 10:33 am    Post subject: Reply with quote
Dan-
Assuming the problem is simple, first, check all the connections, particularly that it's grounded fully, before going any further.
It' much more likely to be a connection problem than an instrument failure.
Dan McNally
PostPosted: Sun May 09, 2010 1:11 pm    Post subject: Reply with quote
Joe,
I think you are right, I must have something funky going on from corrosion, because my raw water wash down does not function either. Guess I will get a volt meter and start tracing the leads to see what the problem is.
Thanks for the input.
Dan
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun May 09, 2010 1:37 pm    Post subject: Reply with quote
If you have several electrical connections on the battery, remove them and clean with small wire brush including the battery posts, then coat with a suitable protectant, Inspect each terminal for cracks, poor crimps,corrosion
Brent Barrett
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun May 09, 2010 5:13 pm    Post subject: Reply with quote
Dan,
I had the same exact problem on my 22 CD/90 hpHonda several years ago.
It was poor connections on the back of the tach. that was the culprit. I told the tech to replace it and he said that was not necessary. Still working fine.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Dan McNally
PostPosted: Mon May 10, 2010 8:01 am    Post subject: Reply with quote
Jack,
I assume that at the back of the tach you mean at the dash? I will start the process of tracing electrical connections this coming weekend when I have some free time.
Thanks for the replies.
Dan
Fishhawk
City/Region: Bon Secour
State or Province: AL
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon May 10, 2010 8:55 am    Post subject: Reply with quote
Back of the tach is likely right.
Same thing happened to me not long ago. From the helm and while watching the tach I just reached around and fiddled with the wires on the back of the tach and found the problem with out even stopping the boat. It was a loose connection.
Dan
"We intend to alleviate global warming's effects of raising ocean water levels by removing enough fish to counteract it all! "
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Mon May 10, 2010 9:46 am    Post subject: Reply with quote
The tach on my 150 every so often goes schizoid on me - the instruction I received were to use the internationally recognized method of fixing instruments - thump it. Works every time, settles down like a rock. :thump :thump
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
jhwilson
City/Region: Mitchell County
Vessel Name: Placid C
Photos: Placid C
PostPosted: Mon May 10, 2010 11:34 am    Post subject: Reply with quote
Had a 90 Honda on my 2002 Lund Alaskan. Once or twice the tach would show almost double the actual rpms. Never could find a connection problem but the "thump" worked each time.
Harper
Pat and Harper, Mitchell County, NC
PostPosted: Mon May 10, 2010 11:51 am    Post subject: Reply with quote
You need to check all connections--from the battery to the engine, and dash connections. To start with brush those larger connections with a brass brush, spray cleaner over the contacts and work the plugs, finally finish off with corrosion block or a dialectric grease.
BrentB
Photos: BrentB
PostPosted: Mon May 10, 2010 1:08 pm    Post subject: Reply with quote
Anyone have a picture of the tach electrical connections (backside of the tach)? Based on the comments, maybe it can be improved. Mine is solid threaded connector like used for a GPS/Chartplotter.
PostPosted: Mon May 10, 2010 4:30 pm    Post subject: Reply with quote
Is this a solid connector, or a coaxial cable? If coax--then use contact cleaner and put some dialectric grease on the fitting when you put it back together.
Jack in Alaska
PostPosted: Mon May 10, 2010 4:49 pm    Post subject: Reply with quote
Dan,
Yes I meant on the back of the tach on the dash. Those connections. An occasional thumping would bring it back also but after awhile that failed to fix it.
Page generation time: 0.0396s (PHP: 64% - SQL: 36%) - SQL queries: 30 - GZIP disabled - Debug on
