Idea for freshwater level
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Wed Apr 28, 2010 2:02 pm    Post subject: Reply with quote
Good idea on the head - IF it works well on the pot. water, I may do the same.
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
Socrateur
City/Region: Danville
Vessel Name: Sea Skipper
Photos: Sea Skipper
PostPosted: Wed Apr 28, 2010 2:16 pm    Post subject: Reply with quote
Here’s a larger hatch to the water tank on my ’05 CD25. The tank now has marks drawn to show number of gallons remaining.
Capt Jay
toyman
PostPosted: Wed Apr 28, 2010 2:26 pm    Post subject: Reply with quote
Jay, where is your water fill ?
Anyone with an '06 KNOW where there tank is ? Is the '06 the same as the '05 ? 'As The World Turns' so do the the questions arise. Razz
Socrateur
Photos: Sea Skipper
PostPosted: Wed Apr 28, 2010 2:48 pm    Post subject: Reply with quote
Water fill on port side gunnel below the running light.
PostPosted: Wed Apr 28, 2010 10:39 pm    Post subject: Reply with quote
If you have the standard Tom Cat head, you can look right into the holding tank, since it is right below the valve--nasty perhaps--but if it gets full, you will know it. The holding tanks are only about 9 gallons. So you do have to manage this. I have the same size tank on my Road Trek RV--that is kept in Calif. I can go a bit over a week with careful use--and other facilities when necessary...
It will be interesting to see how all of these work out. I have had RV's continously (except the 4 years when we were cruising Europe) since 1962--and have had my share of the RV moniters. They work fairly well--but not always. There are lots of choices--and I guess that nothing is perfect.
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Thu Feb 20, 2020 11:35 pm    Post subject: Reply with quote
Toyman, the tank in our 25 is in the bow, I cut hatches in the top of the berths and dug out all the foam, now the tank in front is visable to check the water level, the little screw in one on the v-berth face looks good for lower levels too. Very simple and more storage space and a spot for a 2nd simple depth sounder transducer epoxied to the hull. (No hull core forward of the bulkhead)
Micah Curtis and Dana, RN
Micah, KJ6GUF, Dana, KJ6GXG
PostPosted: Fri Feb 21, 2020 12:49 pm    Post subject: Reply with quote
10 year old thread, with a "thanks" from an one time poster from India....Toyman sold the 255 and I believe a 22, and I don't believe is still active on the site.
Page generation time: 0.0283s (PHP: 63% - SQL: 37%) - SQL queries: 24 - GZIP disabled - Debug on
