Transmit Problem w/ VHF Radio
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sat Apr 10, 2010 9:56 am    Post subject: Reply with quote
Hey Casey, just drill another hole on the other side of the mic. Rolling Eyes Wink Wink
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Sat Apr 10, 2010 10:30 am    Post subject: Reply with quote
Good idea Dave ... and much less messy than cutting my thumb off.
Best,
Casey
Chester
City/Region: home
Photos: Chester
PostPosted: Sat Apr 10, 2010 1:56 pm    Post subject: Reply with quote
You guys are so practical...
PostPosted: Sun Apr 11, 2010 1:37 pm    Post subject: Likely source is the mic connection Reply with quote
Admittedly the most common mic not working problem is "the covered mic hole" but that is really not a mic problem, but an operator problem an and easy fix once learned.
Antenna connection may be an issue, however, if the problem is only in transmission, and not erratic reception too, then it is probably not the antenna.
Likely source is the mic connection. Often loose at the plug, or a wire break, usually where the wire from the mic goes into the plug, causing first intermittent connection then total loss. This can be checked for by swapping mics with one that is known not to have a problem, or by doing a continuity check on the mic wires, one by one, with the mic removed from the radio. (Might want a pro to do this one).
Glad the easy fix worked in the above cases.
jhwilson
City/Region: Mitchell County
Vessel Name: Placid C
Photos: Placid C
PostPosted: Sun Apr 11, 2010 4:04 pm    Post subject: Reply with quote
Yeah Harvey, it was indeed an operator problem with me. I've been using two way radios for many years and usually pick the handset up with my right hand, palm down and key the transmit button with my thumb. This leaves the grill open between my thumb and index finger. With the ICOM handset the actual mike is a small hole low and to the right of the main grill. The way I used the handset caused my palm to cover the little hole. Testing revealed with this little hole covered, no transmission. Who'd thunk? My biggest error was not reading the details in the manual I suppose.
What really threw me off was that I had just replaced a broken antenna that was on the boat when we got her. With the broken antenna both transmission and reception were bad. Since I have very little experience with a soldering iron I assumed I had screwed something up. So, was glad to find the simple solution.
Harper
Pat and Harper, Mitchell County, NC
Page generation time: 0.0492s (PHP: 44% - SQL: 56%) - SQL queries: 22 - GZIP disabled - Debug on
