Wakeboarding off a 19 Angler?
davidwysen
Guest
PostPosted: Thu Jan 07, 2010 8:46 pm    Post subject: Wakeboarding off a 19 Angler? Reply with quote
Hello: I am considering purchasing a 19' Angler, and one of the things I am hoping it will be able to do if pull my teenage kids (one at a time) on wakeboards. I understand this is not a ski boat, but I am wondering given the hull shape and lower powered engines I usually see on these boats if pulling a kid would be an option. Has anyone done or seen this? Thanks, David in Seattle
Tortuga
City/Region: Ventura
C-Dory Year: 1994
Vessel Name: Tortuga
Photos: Tortuga
PostPosted: Thu Jan 07, 2010 10:35 pm    Post subject: Reply with quote
We've had success towing inflatable tubes on the 22' with a 90. I don't know the weight and speed issues involved with wake boarding, but I would think it would work.
Matt
Tortuga
Ventura, CA
chromer
C-Dory Model: 19 Angler
Photos: Checkpoint II
PostPosted: Thu Jan 07, 2010 11:12 pm    Post subject: Reply with quote
My 19 could do it. I have not tried it however. Make sure you get trim tabs for this and other reasons.
Tight Lines!
Checkpoint II (SOLD 10/2020)
Alure Bertram 28
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Fri Jan 08, 2010 12:07 pm    Post subject: tubing Reply with quote
We have pulled teens with inflatable toys for yrs with our c-22 and now with our venture 23 witha f-115 yamaha . we have trim tabs and we use them . I dont know about wakeboarding but I think it could be performed .what speed do you need and how big of a wake do you need .
PostPosted: Fri Jan 08, 2010 6:41 pm    Post subject: Reply with quote
Generally Wake board boats have water ballast aft to increase the size of the wake for tricks. I think that you can buy one of these bladders and experiment to see what wake and how much ballest you can safely carry.
I suspect that even with full ballast, that the wake will be less than a wake board boat.
The second problem is the lack of a tower. The tower puts a towing position up high (to keep the rope from fouling the cockpit, plus allowing the boat to track without being pulled around by the wake boarder. You can ski behind a C Dory; best done with a bridle and pully on the bridel. This same trick could be used with a wake board, but the tricks woould not be at all easy, because the rope is low to the water, and the wake boarder would pull the boat around.
I hae solom skiied behind 25 hp--so you can do any water towing activities with low hp--but it will not be the most effective.
Page generation time: 0.0406s (PHP: 48% - SQL: 52%) - SQL queries: 21 - GZIP disabled - Debug on
