Suggestion for small AC heater
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Tue Dec 01, 2009 11:51 am    Post subject: Suggestion for small AC heater Reply with quote
What do you guys/gals suggest for a small AC heater for the cabin of Napoleon while we are connected to shore power? I would need to run the hot water heater, interior lights, bat charger, stereo, and water pressure system at the same time. I suspect most AC heaters have auto shut off these days if tipped over.
I would like a small heater to take the edge off during spring and fall overnight trips.
Captain Matt
YACD
City/Region: Middle River, Chesapeake Bay
State or Province: MD
Photos: F. Silvestris
PostPosted: Tue Dec 01, 2009 12:18 pm    Post subject: Reply with quote
I don't have a specific brand name but I suggest getting one with several power settings. Mine has 600w, 900w, and 1500w settings. 600w is useful inside the berth with the curtain drawn across. 900w runs with a 1000w Honda generator (although I use the Wallas at anchor) and 1500w can be run with a 2kw generator. I use 1500w to heat the cabin with the berth curtain drawn when the outside temp is around 40. I bought the heater in Home Depot for about $30 a while back. It is about 1' tall and maybe 9" wide - nice and compact.
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Tue Dec 01, 2009 12:28 pm    Post subject: Reply with quote
There are several nice compact ceramic type heaters that put out pretty good heat and are comparatively safe. ie tip switch. The one I have has two heat positions and thermostat control switch.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Tue Dec 01, 2009 12:41 pm    Post subject: Reply with quote
We have the following heater and like it very well.
Rob
Heater
PostPosted: Tue Dec 01, 2009 12:50 pm    Post subject: Reply with quote
Besides what's already been mentioned about the multiple settings and tip switch, I like a heater that's basically flat, to help prevent tipping over.
I set mine in the foot well below the helmsman's seat, as it's basically out of the way when the boat is at rest, and can be set back against the starboard hull wall when not in use, so it doesn't have to be disconnected.
Boont Boater
City/Region: Berkeley
C-Dory Year: 2010
Vessel Name: Aurora
PostPosted: Tue Dec 01, 2009 3:15 pm    Post subject: Reply with quote
We have a small oil filled heater. Like the radiator looking ones that you see in homes. But considerably smaller with tip-over/ shutoff feature.
It doesn't throw out tons of heat but it's completely quiet for undisturbed sleeping.
We got it off of Amazon. I think it was about sixty bucks.
Ranger 29 tug
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Dec 01, 2009 3:18 pm    Post subject: Reply with quote
I have not used it on the boat but have 20 yr old oil filled electric radiator heater with multiple heat settings and wish it had a fan. The surface does get hot and it is tall and can tip over but will turn off. I will check it with my new infrared thermometer. Another Sears sale item
Brent Barrett
PostPosted: Tue Dec 01, 2009 4:41 pm    Post subject: Reply with quote
We use an oil filled heater when the boat is on the lift at home during the winter--just too much room for us, when under way.
When cruising we have one of the ceramic cubes with two settings and it runs fine on either the 1 KW Honda EU 1000 or on any 110 volt circuit on the low setting. Reasonably quiet and keeps the boat warm enough. When it is cold, put up the window coverings, and really cold cut some back packing closed cell foam pads cut to fit the windows, inside of the covers.
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Tue Dec 01, 2009 5:22 pm    Post subject: Reply with quote
CAPT. MATTIE,
i've seen various models of heaters, large and small but haven't really seen any that compare to the one's found at www.victoriassecret.com
my humble suggestion, and that's what you have asked for, would be to re-think you heating problem and take my advice and purchase one or more of the heating models i have highly recommended.
best regards
pat
ps: purchase is final, no returns on damaged property
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Tue Dec 01, 2009 5:26 pm    Post subject: Reply with quote
patrick and linda wrote:
CAPT. MATTIE,
best regards
pat
Do they shut off when they tip over?
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
akroyd
PostPosted: Tue Dec 01, 2009 11:21 pm    Post subject: Reply with quote
CAPT. MATTIE,
best regards
pat
I have owned one of those for several years and believe me it is much more economical to simply purchase, at full retail, a significantly warmer place to keep your boat.
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Wed Dec 02, 2009 12:45 am    Post subject: Reply with quote
Bill on NORO LIM
Did you realy mean...Do they shut UP...when they tip over?
Mike Taylor
330-936-1030
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Wed Dec 02, 2009 11:52 am    Post subject: Heat Reply with quote
Ha ha - well the organic sources of heat are always the best!
Maybe a warm cabin on those cold nights will lead to more organic heat production?
You guys crack me up. Thanks for the recommendations.
Lucky Day
City/Region: Churchton
Vessel Name: Lucky Day
Photos: Lucky Day
PostPosted: Wed Dec 02, 2009 1:44 pm    Post subject: Reply with quote
Does anyone have any experience with this heater from West Marine?
[url=http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/245831/377%20710/0/heater/Primary%20Search/mode%20matchallpartial/0/0?N=377 710&Ne=0&Ntt=heater&Ntk=Primary Search&Ntx=mode matchallpartial&Nao=0&Ns=0&keyword=heater&isLTokenURL=true&storeNum=5002&subdeptNum=12&classNum=543[/url]
Lucky Day
Photos: Lucky Day
PostPosted: Wed Dec 02, 2009 1:54 pm    Post subject: Reply with quote
Could not get the link to appear properly in the reply above. Here is the precise url:
Page generation time: 0.0439s (PHP: 66% - SQL: 34%) - SQL queries: 32 - GZIP disabled - Debug on
