Jon - CLou
Joined: 02 Nov 2003 Posts: 316 City/Region: Port Angeles
C-Dory Year: 1986
Vessel Name: C-Lou
Photos: C-Lou and Pee Wee
Posted: Sat Feb 05, 2005 3:18 pm Post subject: Bow Hatches |
It's time to install a bow hatch. I think we're the only boat in the fleet without one.
Any recommendations on what make and model bow hatch to purchase? |
Joined: 23 Oct 2003 Posts: 5328 City/Region: Warrenton
Posted: Sat Feb 05, 2005 3:45 pm Post subject: |
Jon -
Here is not only the best method for installing a bow hatch, it is also about the least expensive.
Very carefully layout the location, orientation and size of the desired opening. Trace the outline on the deck with a good felt pen. Drill 3/8" holes in the four corners, keeping the entire diameter of the drilled hole within, or to the inside of the layout lines. Then using a good hand held jigsaw, preferably with orbital blade motion, carefully cut along the aft line (if you want it hinged at the back like the traditional CD hatches). Then cut along the forward most line. Be very careful when guiding the saw to not only keep the cut straight, but have a good enough grip on the saw to prevent it from raising up which could allow the end of the blade to bounce off the glass beneath the deck core rather than cut through it.
Now scrounge up some old tires and cut a couple of 2" x 5" chunks out of the sidewall. Take those pieces of rubber and position them near the ends of the aft cut you just made, with the centerline of the 5" dimension stradling and centered on the lines. Get some husky galvanized nails and secure the rubber straps to the deck, using at least three nails on each side of the cut. For safety, you should then go inside the v-berth and bend the protruding ends of the nails over. That will also serve to prevent them from coming loose.
Next, take a 5" length of good 2 x 4 and lay it centered and astraddle the front cut. Drive one husky nail into the end of the 2 x 4 that is on the inside of the cut and right on through the deck. Go inside and bend this nail over, too.
Now you can cut along the two side lines.
There you have it! The heavy rubber straps at the back will serve as spring loaded hinges, and the damn 2 x 4 will hold the front edge of the lid in place. Using this type of latch and hinge arrangement will also allow you to open the hatch in either direction. You can leave the 2 x 4 as is and open the hatch conventionally. Or, you can rotate the 2 x 4 90º (that's why you only use one nail in it) and open the hatch inward. That way, since you are too cheap to buy a windlass, when Cynthia is done pulling the anchor she can simply come back in through the front with little effort.
Hope this helps. _________________ TyBoo Mike
Cynthia - CLou
Joined: 02 Nov 2003 Posts: 58 City/Region: Port Angeles
C-Dory Year: 1986
Vessel Name: C-Lou
Posted: Sat Feb 05, 2005 4:27 pm Post subject: |
Mike, Thanks for the tip! ! !
Hmmm, It's a good thing you pointed out to have Jon bend over the 16 penny nails in the V-berth. Cause' I wouldn't want to mess up my hair if I caught myself on one of em... Not to mention a massive gouge in my noggin'
Jon's still rolling on the floor laughing... CLou _________________ "CLou" on the C-Lou
AKA / "Nurse Ratchet" |
Robbi
Joined: 23 Mar 2004 Posts: 1193 City/Region: Chambers Bay
C-Dory Year: 2023
Photos: C-Run
Posted: Sat Feb 05, 2005 4:32 pm Post subject: |
Tyboo Mike, You been watching the Red Green Show? No, on second thought, there is no duct tape involved in this project. Must be your own innate creative abilities busten out again. _________________ 2023 C-Dory 23 Venture Sport
2003 C-Dory 19
sold 2019
2004 C-Dory 16 Cruiser
Sold 8/2015
2004 C-Dory 19 "C-Run"
Sold 8/2011
1989 C-Dory 16 Angler
Sold 2010 |
Luna C
Joined: 25 Feb 2004 Posts: 404 City/Region: Lake Goodwin/Center Island
C-Dory Year: 2019
Vessel Name: Panthera
Photos: Luna C
Posted: Sat Feb 05, 2005 4:47 pm Post subject: |
But you can learn a lot from watching the Red Green show. _________________ Janet & Chris without CD22 Luna C
Now with Panthera 255 TC |
