DC Electrical Problem
designbug
City/Region: Annapolis
State or Province: MD
Vessel Name: Bella II
PostPosted: Mon Jul 27, 2009 10:58 am    Post subject: DC Electrical Problem Reply with quote
Hi All,
This past Saturday I discovered that my pilot station electrical panel, GPS and VHF Radio stopped working. The engine starts fine, the AC power through the shore connection works and so does the anchor windlass. I checked all the fuses, which all seemed fine, and checked all the reset buttons on the panel itself. There is a reset switch near the battery selector switch which I have reset several times to no avail.
My wife, Laurie, said that she turned on our inverter (300 watt?) which was attached to the panel's 12 volt plug while we were connected to shore power to run the ipod - could this have caused some kind of short?
Any suggestions would be appreciated.
Thanks, Dick
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Mon Jul 27, 2009 11:17 am    Post subject: Reply with quote
Don't think the inverter and ipod is the issue.
How many batteries do you have on your boat?
Depending on how whoever wired in your batteries, some items may be wired to the crank battery...which seems to be fine....while others may get power from one, or more "house" batteries.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
designbug
PostPosted: Mon Jul 27, 2009 11:48 am    Post subject: Reply with quote
Byrdman
Hi Byrdman,
I have two Group 24 batteries, which I believe is the standard CD25 setup. Using the battery selector switch either of the batteries can be used to start the engine and both appear to be working (I'll retest again this evening to be sure).
Thanks, Dick
PostPosted: Mon Jul 27, 2009 3:12 pm    Post subject: Reply with quote
Dick-
What I'd do is get a voltmeter or continuity tester and start back as far as you can and trace the power's flow/continuity from the battery(s) forward through the fuses and switch panel to the dash, looking for the break in continuity or voltage loss in the circuit.
designbug
PostPosted: Tue Jul 28, 2009 10:28 am    Post subject: Reply with quote
I think I found the problem. I bypassed the main circuit breaker and dc power was restored. I will replace the main circuit breaker this weekend.
Thanks for everyone's advice, Dick
Byrdman
PostPosted: Tue Jul 28, 2009 10:36 am    Post subject: Reply with quote
Cool.... but, now,.... what caused the main breaker to go bad? That is very, very rare.... I think..
Byrdman
designbug
PostPosted: Tue Jul 28, 2009 11:00 am    Post subject: Reply with quote
Good question? In my research I noticed that Bill on Barnacle Bill and Pat on Daydream had similar problems - not sure about others. This web site is a great resource.
Thanks, Dick
designbug
PostPosted: Fri Jul 31, 2009 9:30 am    Post subject: Reply with quote
Last night I replaced the main circuit breaker and dc power was restored.
usmcdory
City/Region: Morehead city
Vessel Name: USMC dory
PostPosted: Sun May 16, 2010 9:43 pm    Post subject: Reply with quote
hey dick, I had a very similar problem today. lost all DC power on my 2009 25 C-dory, GPS, radio, and all rocker switch operated electrical items. Windlass, trim tabs etc continued to work just fine. No lights on my control panel, no power, no nothing. where did you find the main circuit breaker that you replaced. I found a resettable CB near the #1 battery and perko switch which was not popped and I reset anyway. still no power. looked all around the distribution panel in berth behind sterring wheel kick panel but could not find anything that looked
like a main CB for the entire panel. thanks USMC dory
USMC dory is a 25 ft C-dory with a 135 honda 4 stroke docked in Atlantic Beach , NC. Linda and I take her out often and enjoy spending peaceful nights on the sound.
PostPosted: Sun May 16, 2010 11:03 pm    Post subject: Reply with quote
See the answer to your other post--basically you need to get the volt meter out and check the entire circuit. A volt meter needs to be in every tool kit.
PostPosted: Sun May 16, 2010 11:36 pm    Post subject: Reply with quote
And I want to add a thought to Bob's very true post. Learn how to use that voltmeter.
For DC circuits that's a simple thing. Even Pat Anderson is learning.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon May 17, 2010 12:21 am    Post subject: Reply with quote
Boris, how much beer did Pat send you to make that statement?
PostPosted: Mon May 17, 2010 12:10 pm    Post subject: Reply with quote
From Pat:
"Now, although there is 13.6 volts at the socket on the circuits for the lights and turn signals (the only ones I checked), when I insert the trailer plug, none of the lights work. The trailer is hooked up, and I have used the trailer frame as ground for my tests, so I don't think it is anything a simple as a ground wire, bu there is a white wire hanging loose out of the trailer harness. "
That was Step 1. For Step 2, he just needs to learn what wires do.
designbug
PostPosted: Mon May 17, 2010 1:16 pm    Post subject: Reply with quote
It sounds like you found the main circuit breaker. Mine was located near the battery selector switch.
The way I found out that the circuit breaker was bad was by bypassing it. I did this by disconnecting the wires going to the breaker and then briefly touched them together where I noted that power was restored.
I seem to recall that the bad breaker was Sea Dog(?) brand and I replaced it with Blue Seas(?) brand - about $40-$50 at West Marine. I haven't had a problem since.
Thanks, Dick
PostPosted: Mon May 17, 2010 8:01 pm    Post subject: Reply with quote
Dick, that's one of the beauties of a voltmeter. You don't have to wire around a suspected bad switch, breaker, fuse, etc. What if the breaker had broken because of a fault downstream? You would have connected 30 amps of 110 VAC directly to a short. That would have been more exciting than you'd like to remember.
Voltmeters are good things to use. Saves a lot of guessing and can be quite safe.
Page generation time: 0.0677s (PHP: 42% - SQL: 58%) - SQL queries: 32 - GZIP disabled - Debug on
