CB Light
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Fri Jul 03, 2009 1:13 pm    Post subject: CB Light Reply with quote
The light on my main 110V breaker isn't illuminated, neither is the reverse polarity light - everything seems to be working fine and the other indicator lights on the panel are working - do I have a problem ? Don't really want to fix it until there is a problem, my "fixes" usually create problems enough.
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
PostPosted: Fri Jul 03, 2009 5:19 pm    Post subject: Reply with quote
Dave, I assume this is when you're plugged into shore power?? Wink
If so, and you don't have polarity reversed, that light should NOT be on.
Do the 110V outlets in the cabin work? Are any of the other lights on the shore power panel illuminated (water heater, outlets, etc)?? Sorry, on edit, you said they wefre.
If they do, then there is just an indicator light problem on the 110v main breaker, not to worry, you can replace it at your leisure.
If it's more complicated than that, give us some more information...
toyman
PostPosted: Sun Jul 05, 2009 9:35 pm    Post subject: Reply with quote
I believe it's just an indicator problem as everything seems to be working ok. Thanks.
Page generation time: 0.0277s (PHP: 59% - SQL: 41%) - SQL queries: 20 - GZIP disabled - Debug on
