Tilt Control, Honda 75
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Wed Mar 04, 2009 9:22 pm    Post subject: Tilt Control, Honda 75 Reply with quote
Had the tilt control quit working on our Honda 75 hp. Neither the rocker switch on the motor head or throttle switch will work. Had to pull out of the water and manually lift the motor. The wiring diagram shows a relay which I could not locate. I checked all fuses but apparently the tilt motor just has a relay. Both worked fine this morning. Any ideas?
Other than that, had a fun day on Lake Powell today... 70 deg, sunny, yet windy with a frontal passage. Our first time on the water with our "new to us" C-Dory.
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Tue Mar 10, 2009 12:37 am    Post subject: Reply with quote
You know you are hooked on this website when you start answering your own posts. The fix in this case is to replace the tilt motor. Is there a good internet supplier of Honda or aftermarket tilt motors? In the process of determining the problem, I did learn how to manually raise and lower the motor. I also learned that the tilt motor will operate until replaced by tapping on it will holding the rocker switch.
PostPosted: Tue Mar 10, 2009 6:13 am    Post subject: Reply with quote
Ken, try this site
Let us know how it works...
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Tue Mar 10, 2009 8:39 am    Post subject: Reply with quote
Or you could contact one of the many Honda/C Dory dealers and ask them . Almost like "shopping locally "
Marc
Wefings Marine Website
Since 1909
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Tue Mar 17, 2009 6:19 pm    Post subject: Reply with quote
I removed the tilt motor and took it to an auto electric shop. They rebuilt the motor for $20. It is re-installed and works fine. Sure beats $282 for a Honda replacement, however I will have to deal with the guilt of not pumping more money back into the economy.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Mar 17, 2009 8:55 pm    Post subject: Reply with quote
Rumor is that Homeland Security is now looking for you. Seems like you have to have a commercial license to pull and rebuild tilt motors. Looks like you get at least two weeks in the electric chair.
I just couldn't live with all that guilt...
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Wed Mar 18, 2009 12:00 am    Post subject: Reply with quote
The government is presently occupied trying to figure out what happened to 500 bazillion tax dollars at the moment, so I'll be under the radar for a few days.
Page generation time: 0.0506s (PHP: 59% - SQL: 41%) - SQL queries: 24 - GZIP disabled - Debug on
