New anchor coming up upside down
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sat Feb 28, 2009 9:29 am    Post subject: New anchor coming up upside down Reply with quote
I have a new anchoring setup on my Tom Cat -- it's an EZ Anchor Puller (a Ramsey winch adapted for marine use) with a Manson Supreme anchor connected to 30' of chain and 170' of Brait. Since I have started using it here, the anchor has started coming up upside down. Any ideas on what might be happening and how to fix it? I could turn the shackle over but would that do the trick? Anyone else encounter this problem?
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Sat Feb 28, 2009 9:33 am    Post subject: Reply with quote
You could turn the boat over... Laughing
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sat Feb 28, 2009 9:41 am    Post subject: Reply with quote
Warren,
Is your anchor on a shackle or a swivel? I went from a shackle to a swivel because of the problem you describe and while not perfect, (still the occasional upside down recovery), retrievals have normally brought the anchor in upright.
Patti and Barry
formerly C-Cakes, now
rving around N. America
Doryman
Photos: Lori Ann
PostPosted: Sat Feb 28, 2009 9:43 am    Post subject: Reply with quote
It's a shackle. A really good one. Twisted Evil Any suggestions for a good swivel to get?
PostPosted: Sat Feb 28, 2009 11:14 am    Post subject: Reply with quote
Look at this swivel:
Defender
Anchor Chain Rode Swivel
Fits 1/4" to 5/16" chain
Item #: 001401
Manufacturer: ACCO CHAIN
Model #: 4406-40001
Shipping Weight: 1.15 Lbs.
Our Price: $33.99
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sat Feb 28, 2009 11:19 am    Post subject: Reply with quote
Since swivels are not as strong as a shackle, I would go oversize. The limiting factor may be the forward roller on your anchor bow support. Mine is stainless and, I think, made by Seadog. Many people stick with shackles because of the strength issue.
flrockytop
Vessel Name: The Last One (to date)
Photos: C-LOVER
PostPosted: Sat Feb 28, 2009 12:16 pm    Post subject: Reply with quote
Warren,
I have had this happen to mine. I think the rode gets a twist in it. I have turned the shackle over and that has fixed it. Since the twist also causes problems with my windless, I also periodically have to get the twist out of the rode.
2007 22 Cruiser
Track Me HERE
NA4RR
Roger Rockwell
Pensacola, Fl
Ancora Latina
City/Region: Florianopolis - Brasil
State or Province: AL
PostPosted: Sat Feb 28, 2009 12:25 pm    Post subject: Re: New anchor coming up upside down Reply with quote
Hi Doryman,
This problem is a very simple one and the solution is also very simple Smile ...
Your anchor is following the physical law of the « lesser effort » Rolling Eyes !
Let’s me explain... When your are weighting your anchor, your boat is going slowly forward... Then look at your anchor on the water: following the « lesser effort » law, your anchor is set with the tip facing forward... If then you lift your anchor, it will come on the bow roller upside down...
Now try the following : - your anchor still at the surface of the water, go just a little bit BACKWARD and look at your anchor, it will set itself in the right position and you can lift it without problem..
Good and safe anchoring
Joćo
Ancora Latina
(P.S. this answer is not a SPAM! Mr. Green )
www.ancoralatina.com
Doryman
Photos: Lori Ann
PostPosted: Sat Feb 28, 2009 7:02 pm    Post subject: Reply with quote
Thanks, everyone. I will start with the backing-up trick and go from there to the other suggestions, if necessary.
ccflyer
City/Region: Bradenton, FL
Vessel Name: Retriever
Photos: ccflyer
PostPosted: Sat Feb 28, 2009 7:19 pm    Post subject: Reply with quote
Ancora Latina:
Now there's good solution from a long way south of the border! Thumbs Up
Good to see an international chapter(?) of the C-Brat brethern checking in Laughing
Do you own a C-Dory & What type of anchors do you manufacture?
There is a very fine line between "hobby" and "mental illness".
Ancora Latina
PostPosted: Sat Feb 28, 2009 8:45 pm    Post subject: Reply with quote
ccflyer wrote:
Ancora Latina:
Hi ccflyer,
Thanks for your interest, but as I do not want to "advertise" on the forum, would you be kind enough to contact me direct on my E.mail:
info@ancoralatina.com or www.ancoralatina.com
Regards
Joćo
PostPosted: Sat Feb 28, 2009 8:55 pm    Post subject: Reply with quote
Warren has a system which allows the rode and chain to be taken directly onto a drum which it is stored on. He is using a plait line, with no twist (like 3 strand) and chain ( no twist). At some point the orientation has become reversed--where with 3 strand it may be each time because of line twist.
I find that my Manson Supreme will automatically turn correctly (no swivel--I don't trust them, because if they are side loaded they may fail)I believe Warren has a different type of roller (two pieces and pivots down) than I do, and it may not allow the anchor to twist (may not put as much righting load on it). But it is worth trying to put the top of the shank of the roller, and see if it twists over to the correct position.
Yes, going in reverse, may put the anchor in the proper orientation, but since the anchor has to come up about 3 feet from the water, it may twist back, depending on the pressure from the chain on the drum. We have always found that our Manson came back to the proper position, without a swivel, if it was off, by backing down a few inches, waiting a short time and the repulling and it would flip back up correctly.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sat Feb 28, 2009 10:55 pm    Post subject: Anchor Reply with quote
I too don't trust swivels, not for the loads that can be experienced anchoring in strong winds or the force that may be necessary using engines to break her free. I've been fortunate and never had my Lewmar Delta anchor come up backwards whether drifting forward or backward. I use 3 stand nylon line spliced to chain.
Captain Matt
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Sun Mar 01, 2009 7:51 am    Post subject: Reply with quote
Hey, I love my swivel set up. I use the swivel anchor connector (WM #289280), which assembles with an allen wrench.
But, if you connect it directly to the anchor shank, you're asking for trouble, since the connector is not designed to allow sideways motion at it's joint. So, as the boat swings, you're using the connector in it's weakest mode to swing the anchor. I handle that with a shackle between the anchor, and the anchor connector. Mount the shackle with the screw pin through the anchor, and the loop facing the vessel. Then, attach the anchor connector to the shackle loop. Now, you have a little more than 180 degrees of swing before the connector would begin to side load.
I suppose you could still have problems this way, but I haven't yet. And, when the anchor comes onto the bow roller, it quickly takes the correct orientation, without any chain twist. Since there's only a few inches of chain between the windlass gypsy and the anchor shaft, I seems to me that without the swivel, I'd be messing around with the chain half the time I raise the anchor.
Works for me.
2003 CD22 Cruiser with Honda 90
Page generation time: 0.057s (PHP: 73% - SQL: 27%) - SQL queries: 31 - GZIP disabled - Debug on
