Rough Riding 16' Cruiser in Chesapeake Bay chop
DoryLvr
City/Region: Cape Charles
Vessel Name: Litl' Tug
Photos: Litl' Tug
PostPosted: Mon Feb 16, 2009 6:56 pm    Post subject: Rough Riding 16' Cruiser in Chesapeake Bay chop Reply with quote
After 5 and a half years of looking at C-Dorys, I am finally a new C-Dory owner (today was the first day to take my 16' Cruiser out!) However, I was surprised at how rough the C-Dory rode in the Chesapeake Bay chop. I also own a 15' Hobie Power Skiff and it flies through and over the chop pretty smoothly. I am assuming it is because the C-Dory is flat bottomed with no insulation. I found today it rode much better at about 8-9.5 knots than wide open (it has a 50HP Yamaha). Is this a normal observation or am I not trimmed out properly? What is the best speed for running these boats in chop and smooth water and are they normally pretty noisey when running (the fwapping of the water under the hull)
Tivo Romero, CWO2, USCG (Ret)
DoryLvr
16' Cruiser - Litl' Tug (SOLD)
"The art of seamanship is never allowing yourself to get in a situation where you have to know anything about the subject."
PostPosted: Mon Feb 16, 2009 7:08 pm    Post subject: Reply with quote
The C dories have very little deadrise (almost flat bottom) and will pound in any significant chop. If you put the bow down, it will alleviate this to some degree.
On the other hand, the Hobie Power Skiff has considerable deadrise--it is described as a "deep V" and to my recollection has about 20 degrees of dead rise vs 2 - 4 degrees for the C Dory line.
When one buys into the C Dory family they have to realize that they run best at lower speeds in chop--but that they do plane at low speeds, and a hand on the throttle, as well as on the helm will allow you to work the boat through the chop, by going a bit off hitting the waves head on.
Enjoy your boat.
PostPosted: Mon Feb 16, 2009 7:09 pm    Post subject: Reply with quote
It's pretty normal for the C-Dory boats to run rough in chop. The flat bottom is great for fuel economy and not so great for chop. As has been said many a time on this site, all boats are trade offs and the trade off of a dory style hull is fuel economy and stability (in flat water) against a rougher ride in the chop. That said, getting the bow trimmed down some can really help. With a 16, you can do trim tabs but most here have been very satisfied with the improved bow trim afforded by permatrim fin mounted on the main engine. Nonetheless, going slower is the primary answer for dealing with chop.
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Mon Feb 16, 2009 9:18 pm    Post subject: Reply with quote
Get a permatrim it will make a remarkable difference in performance on the 16. I found that for beam to beam trim a cooler in the back simply handled this by sliding it side to side but the trim tabs work well also for additional $. And has been said trim the bow down slow down and enjoy the ride. Instead of plowing thru the seas like a deep vee the C-Dory just bobs over like a cork. A canopy over the back of the cabin will help some with the motor noise and I'm told the spray on mascoat insulation in the cabin helps also.
marvin
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Feb 17, 2009 11:46 am    Post subject: Reply with quote
What you are experiencing sounds similar to my 16'. The permatrim has made a big difference however. Slowing down is required when the chop starts to get up to about 2'.
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Tue Feb 17, 2009 12:22 pm    Post subject: Reply with quote
16 cruisers tend to be stern heavy. You should do everything you can to get the bow down. It will do much better in chop in that attitude. The 16 angler has less weight to the stern and doesn't have as much problem in this area.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
C-Nile
City/Region: Connecticut
State or Province: CT
C-Dory Year: 2012
Vessel Name: Betty Ann
Photos: C-Nile
PostPosted: Tue Feb 17, 2009 8:01 pm    Post subject: Reply with quote
I have a C-Dory 16 cruiser (C-Nile) and use it mostly on Long Island Sound.
1) In 3' seas (I'm out there by mistake), it's rough going. Slam! Slam! Slam! We go 7 mph or less. We're going so slow, that the boat is not easy to control. A permatrim would probably help, but I'm afraid to install one for fear of negating my 6 year warranty.
2) In 2' seas or more, we stay home. Again, the boat is plenty safe, but we have to go less than 11 mph with the motor at full trim
3) 1' to 1.5' is normal, and we do about 15 mph with full trim
4) Less than 1' -- 5,400 RPM, slight trim, 22 mph.
The CD 16 is a slow boat, and gives a rough ride at high speeds. However, my wife and I are not on the water for speed, and we placed safety above all other factors. We feel very safe in this boat. In an earlier communication, I detailed how we went through 5-foot standing waves (foolishly). It was harrowing, but we made it safely while a lessor boat would have broached and perhaps inverted. So, we lived for another day, much wiser and vigilant to avoid such circumstances like that in the future.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Feb 17, 2009 8:52 pm    Post subject: Reply with quote
I seriously doubt that the Permatrims will affect your warranty. I have had them on my Yamaha 150s almost from the get-go and they have never been a factor in my warranty claims.
Doryman
M/V Lori Ann
Anacortes, WA
Steve Grover
City/Region: Lake Tahoe
C-Dory Model: 19 Angler
Vessel Name: Tee Ten
PostPosted: Tue Feb 17, 2009 9:29 pm    Post subject: Reply with quote
Get the Permatrim. It was designed for you boat and motor Thumbs Up
Lucky Day
City/Region: Churchton
State or Province: MD
Vessel Name: Lucky Day
Photos: Lucky Day
PostPosted: Wed Feb 18, 2009 8:26 am    Post subject: Reply with quote
Found this in the Permatrim Forum on thehulltruth.com -- refers to engine warranties:
http://www.thehulltruth.com/forums/thread-view.asp?tid=201241&posts=3&highlight=warranty&highlightmode=1#M2093348
1TUBERIDER
City/Region: Crescent City
PostPosted: Wed Feb 18, 2009 9:16 am    Post subject: Reply with quote
Our boats can handle a lot. The pounding is uncomfortable so I slow down to where I don't slam so hard. Going into the swell is always going to be slower due to the pounding but running with it should be smooth.
I run in the ocean, so often when I boat, the swell is minimum of 6ft. With wind and chop running into it I will stay alert with throttles so that when going over the swell I have slowed down and then when going down the back you can accelerate again. Again engine trim helps smooth the ride.
As to weight, I believe to much weight forward will increase a boats tendency to broach. I run in the ocean where surfing a swell is part of the fun. I will keep my load balanced and biased towards aft. I like to have clean shorts on and poking my bow into the trough of a swell will have me making a mess.
Sea ya
lloyds
PostPosted: Wed Feb 18, 2009 11:07 am    Post subject: Reply with quote
c-nile, you need the permatrim, or at least some foil. I will even give you my old dolefin if you want, just pay for the postage. It works and I am sure even with it you would see a difference.
C-Nile
C-Dory Year: 2012
Photos: C-Nile
PostPosted: Wed Feb 18, 2009 6:36 pm    Post subject: Reply with quote
Warren, Tee Ten, Lucky Day Et. Al.:
Many people have been telling me to get the Permatrim. When I'm going slow in rough water, I can't get the bow down, and the boat sort of fishtails. After putting 140 hours on the motor last year, I think you all are right, and I'll install one this year.
Thanks!
Rich
DoryLvr
Photos: Litl' Tug
PostPosted: Wed Feb 18, 2009 8:35 pm    Post subject: Reply with quote
Everyone is recommending the Permatrim by name. What do people think about some of the other hydrofoil products out there, dolefin, SE Sport hydrofoil, etc. They are supposed to do essentially the same thing. Reason I ask is that Permatrim seems to be a very west coast centric product. Also the availability of the others is very wide.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Wed Feb 18, 2009 9:12 pm    Post subject: Reply with quote
Not sure how helpful this will be as I can only speak to the Permatrim. It is the only kind I've used. Permatrims are specifically designed for your motor, they're not a one size fits all product. They are quite strong, easily installed and the design seems to work. They have been on my 22, (twin Honda 40's) for one year and have made quite a difference. People who have installed them on 16's seem to like them the most. I use them almost exclusively for fore and aft trim. My Bennett trim tabs are now just used for lateral trim. They are made in New Zealand but the dealer is in Wisconsin, (Shipyard Island Marina), and has been very good to work with. I think you will find several references to people who have had some other foils on their boats and have switched to Permatrims. I would contact Shipyard Island Marina and talk with them. Good luck.
Patti and Barry
formerly C-Cakes, now
rving around N. America
Page generation time: 0.0455s (PHP: 66% - SQL: 34%) - SQL queries: 32 - GZIP disabled - Debug on
