battery wing terminal covers?
marco422
City/Region: Salt Spring Island
Vessel Name: Gaiasika
Photos: Gaiasika
PostPosted: Tue Dec 02, 2008 1:10 am    Post subject: battery wing terminal covers? Reply with quote
Has anyone found or jimmied good rubber covers for the wing terminals on the battery to prevent sparks if the anchor chain was ever to touch down there (scary thought)?
PostPosted: Tue Dec 02, 2008 1:30 am    Post subject: Reply with quote
dont know of cover you can buy, but you might try liquid rubber. its a product that you can paint on. its made for uses like this.
heres a link http://www.plastidip.com/industrial_solutions/Liquid_Tape_-_Electrical_Insulation
marco422
Photos: Gaiasika
PostPosted: Tue Dec 02, 2008 1:42 am    Post subject: Reply with quote
Thanks, that would probably work well, since I won't be undoing them very often...
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Tue Dec 02, 2008 2:09 am    Post subject: Reply with quote
Marine stores sell rubber boots in red and black to cover the battery terminals. Its best to replace the wing nuts with hex nuts and tighten with a wrench which is too short to reach both terminals and cause a short. Shorting battery terminals can cause the battery to explode.
Larry H
A C-Brat since Nov 1, 2003
PostPosted: Tue Dec 02, 2008 8:21 am    Post subject: Reply with quote
A battery box with a full top cover works well too.... Thumbs Up
JT
City/Region: JUNEAU
C-Dory Year: 1990
Vessel Name: Lil Toot
Photos: Palomino
PostPosted: Tue Dec 02, 2008 10:32 am    Post subject: Wing nut covers Reply with quote
Iboat.com has wingnut terminal covers.
JT
F/V 'Palomino" Wink
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Tue Dec 02, 2008 11:17 am    Post subject: Reply with quote
I think I still have the rubber ones that came with my new batteries....I don't use them as my batteries are totally sperate....I will be glad to give em to you if you will send me your mailing address....or I think I have seen some at West Marine ..... I don't like the darn wing nuts...they can come loose...and I now have a blown recifier on one motor caused by a loose terminal.... I will from now on...use nuts that I can get a wrench on....no more wing nuts...
Joel
SEA3PO
Page generation time: 0.0393s (PHP: 61% - SQL: 39%) - SQL queries: 20 - GZIP disabled - Debug on
