Winterizing
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time
IdleUp
City/Region: Smith Mountain Lake
C-Dory Model: R-25 Tug
Vessel Name: Linda Sue
PostPosted: Thu Oct 02, 2008 9:02 am    Post subject: Winterizing Reply with quote
I think I've read just about all the posts on the subject and it seems as if this is going to be a real job.
It appears the house water pump is hidden somewhere under the helm step. Do you have to remove the refrig or the cabin heater to access it. I wanted to gain access to the intake to run RV juice through the lines. If possible, I'll relocate it under the sink.
I Think I'm OK on the A/C since I can gain access of the intake on the manifold.
I have not yet found the forward bilge pump.
Shower slump won't be a problem.
I have a few Boat Safe heaters however, I don't think the heat will make it forward
Looks like I can drain the water heater - I seen a by-pass kit on Boaters World.
Seems as if boats should follow procedures of RV's and have wintererizing ability like they do
R/C Helicopter Pilot - 09 Ranger 150
My Other Hobbies:
www.rotory.com - www.bigpickup.com
terraplane
City/Region: chesapeake bay
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Thu Oct 02, 2008 12:06 pm    Post subject: winterizing r 25 Reply with quote
Would anyone be willing to post a step by step procedure for winterizing the r 25. I plan to have my local mechanic do it, and he is good, but has not done a ranger 25. Simple language, and simple instructions...how to get to things...etc.
I'm pretty good at running parties for C dory, playing banjos, ....but a dunce on mechanical issues.
terraplane
IdleUp
PostPosted: Thu Oct 02, 2008 1:22 pm    Post subject: Reply with quote
Well, I'm planning on getting it figured out - I'll be happy to share it with the board.
IdleUp
PostPosted: Thu Oct 02, 2008 1:38 pm    Post subject: Reply with quote
I just called John at the factory and he advised me the fresh water pump is accessible by removing the heater at the floor of the helm.
The forward bilge pump is accessible under the step. However, it should be dry since it's located so high.
captd
City/Region: Chain of Lakes
State or Province: MT
C-Dory Year: 1994
Vessel Name: Kon Tiki
Photos: Hunky Dory
PostPosted: Sat Oct 04, 2008 9:58 am    Post subject: Reply with quote
I have done the Mis Dee twice. Lets see if I can remember>
1. pumped out all the water from tank that I could.
2. pulled the plug on the hot water tank
3. used air to blow air conditioner at the intake.
4. Drained the shower hose
5. Pulled plug on exhaust riser
6. Drained raw water strainer
7. drained water from fresh water strainer
8. Blew air through gen set intake
9 Drained exhaust on gen
10. Make sure you have anti freeze in the fresh water side of the exchangers.
11. Blow air through wash down lines and pump.
12. Last but not least, I used camper type antifreeze in the tank and run until I got color out of ever faucet. Poured some in toilet, sinks, shower sump. Pour some in the bilge to get some in the pump.
Note: The stuff tastes terrible and takes lots of water to get rid of it.
(tanks full) I am going to try not to use the stuff in the future.
I put a by-pass on the hot water heater. Worked good to shut off water to the tank. But something was wrong with valves and had to take it off to use hot water later. Don't use any more air pressure than needed to move the water out. I found some kind of gadget that allowed me to blow air through the intakes. Can't remember what it was. (senior moment) When I find it I will let you all know. What ever it was, it worked well.
There maybe more to do , Jump right in if you think of anything.
Thats all I can think of right now. The instruction books on the engines, gen set included, tells you how to take care of them.
captd
100 ton Master
1986 Sport Craft 27 ft , 240 hrs Yanmar sold
2000 22 ft C-Dory (Hunky Dory) sold 2006
2007 25 R Ranger (Mis Dee) sold 2008
2009 25 R Ranger (Lucky Fin) sold
1994 22 ft C-Dory ( Kon Tiki )
terraplane
Vessel Name: BANJO
PostPosted: Sat Oct 04, 2008 1:35 pm    Post subject: winterizing Reply with quote
capt d.
Thanks for the info. If you think of anything else, let me know. I'm going to show your list to my guy. Excuse my ignorance, but how do i find the access hot water heater?
terraplane tom
IdleUp
PostPosted: Sat Oct 04, 2008 7:31 pm    Post subject: Reply with quote
captd
Thanks for the detailed list!!
Starry_Night _Joe
City/Region: Virginia Beach
Vessel Name: Starry Night
PostPosted: Sat Oct 25, 2008 12:21 pm    Post subject: Re: winterizing Reply with quote
terraplane wrote:
capt d.
terraplane tom
Tom
Open the aft stbd deck hatch in the fantail.
The forward bulkhead is the electric hot water heater.
You can trace the supply and return lines pretty easy.
Joe Bradley
Starry Night
Virginia Beach, VA
TomRay
Dealer
City/Region: Punta Gorda
PostPosted: Sat Oct 25, 2008 12:52 pm    Post subject: Reply with quote
Wouldn't it be easier to just move to Florida? Wink
Gulf Island Sails
PostPosted: Sat Oct 25, 2008 12:59 pm    Post subject: Reply with quote
Or Puget Sound, where you wouldn't have to endure all that bloody sunshine! It may be gray and damp, but we boat all year round here too - and no hurricanes!
TomRay
Dealer
PostPosted: Sat Oct 25, 2008 2:48 pm    Post subject: Reply with quote
No hurricanes? When do you go sailing? Wink
captd
C-Dory Year: 1994
Photos: Hunky Dory
PostPosted: Sat Oct 25, 2008 5:58 pm    Post subject: Reply with quote
After spending a few days at the factory and seeing the changes that have been made. Winterizing is a lot easier. The central strainer covers three things all at once. Open the top and pour anti freeze (RV type) into the bowl. shut off the intake, (the through hull ), Have some one crank the engine. pour in anti freeze until it comes out the exhaust. Run the wash down pump until it pumps red after shutting off the other two, toilet the same way. You should be able to blow out the air conditioner (Diaphram pump) Pour anti freeze into sinks, shower until it pumps red. If any water in the bilge just pour in some anti freeze.
No need to get to the pumps anywhere. Pull the plug on the hot water heater. Pump out as much drinking water as possible. Pour in the red stuff, lots of it. Pump until it comes out of all of all fresh water out puts. Shower, sinks, Etc. You do not have to pay anyone. Take your time , use lots of anti freeze.
captd
IdleUp
PostPosted: Sun Oct 26, 2008 5:26 pm    Post subject: Reply with quote
On my boat the strainer supplies the engine - wash down and the A/C - so you'll want to fire up the A/C to get the RV juice through the system.
My head is on a separate valve on the port side of the boat.
By the way, there might be a trap on the A/C evap drain so you might want to look that over as well.
Regards,
captd
C-Dory Year: 1994
Photos: Hunky Dory
PostPosted: Mon Oct 27, 2008 6:59 pm    Post subject: Reply with quote
Regards,
You might be right about what comes off the strainer. I haven't taken the shrink wrap off yet, and my memory is short.
How do you get the other two? Last year on the 2007 I pulled the plug on the silencer box on the genset, lot of water there. I think I slipped a hose into the through hull and into a jug of antifreeze. Cranked the engine.
Andrew went through the strainer part, but didn't see him do the other two.
Maybe Andrew will enlighten us..............
captd
IdleUp
PostPosted: Mon Oct 27, 2008 8:32 pm    Post subject: Reply with quote
I wish I wish I could help you but i don't have a generator on mine so you might be right since that is another hose needed on the intake.
I'm sure one of the guys here have a gen could shed some ligt on the subject.
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time All times are GMT - 5 Hours
Page generation time: 0.0654s (PHP: 69% - SQL: 31%) - SQL queries: 32 - GZIP disabled - Debug on
