Prop Fell Off at the Ramp
Post new topic   Reply to topic    The C-Brats Forum Index -> Propellers
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Mon Oct 06, 2008 1:40 am    Post subject: Prop Fell Off at the Ramp Reply with quote
When I came back into Whittier today after the last trip of the season, I put the motor in reverse to find nothing happens. Fortunately I wasn't going to fast and was able to dock without any problems. As soon as I looked at the lower unit, the problem was obvious. We were lucky in that the water was clear and about 9 feet down you could clearly see a stainless prop.
We had just covered about 75 miles from Green Island and had put the motor in reverse the night before when setting the anchor. I visually inspect the prop each time before I launch for security. I was using the Honda retaining clip and three of the tabs were least 1/8 inch below the retaining ring. The motor had at least 300 miles on it since the prop was last removed. The question is what failed. I don't see three tabs breaking at the same time. The nut can't back off if the tabs are depressed. Since the Quicksilver prop uses an insert for the Honda spline, my initial guess is the retaining ring separated from the insert.
Has anybody heard of this happening before? By the way, it was quite a chore to lasso a prop in 10 feet of water with a rising tide. Thanks to some duct tape used to attach an oar to a boat hook we got a loop around two of the blades and the hub (we used a 2 lb halibut weight to get the rope to the bottom).
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Mon Oct 06, 2008 4:49 pm    Post subject: Reply with quote
Tom,
Not acquainted with that type of retaining clip, I’ve always just used a cotter pin; glad you were able to retrieve the prop.
I’m impressed you made it out to Green Island in October, and a little jealous; Tucked Triple J in for the season weekend before last. If I could have found some crab pots in town I would have gone out last weekend, but the Tanner/Golden King crab fishery is so new know one has pots.
BTW, I’ve been getting great fuel economy by not trying to fill that 3rd fuel tank. Shocked
Take care..
Boatless for now but looking
PostPosted: Mon Oct 06, 2008 7:09 pm    Post subject: Reply with quote
Tom I think that you have to have a pin to hold that thing in place even with the retaining clip. At least it was at the end of the trip and not in the middle.
PostPosted: Mon Oct 06, 2008 8:26 pm    Post subject: Reply with quote
Just for clarification, is this what we're discussing?
The iboats.com catalogue says it replaces OEM equipment for
CHRYSLER FORCE F697140
HONDA 90508-ZW1-003 For: 75-90 HP
MERCURY MARINE 14-31210
MERCURY MARINE 14-816629
PLEASURECRAFT R096117
I have this type of set up on my 40 hp Mercury 4 stroke motor on my pontoon boat, and s a similar set up on my two Mercruiser outdrives on the Sea Ray. No problems with them for me.
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Mon Oct 06, 2008 8:41 pm    Post subject: Reply with quote
Is there a chance someone was trying to steal your prop and had lossened the nut?
marvin
tpbrady
Photos: Bidarka
PostPosted: Mon Oct 06, 2008 11:46 pm    Post subject: Reply with quote
Joe,
That was it. I checked the prop the night before in the driveway and all was as it should be. I think I am going to go back to the classic cotter pin or the same clip augmented by safety wire. I am leaning toward a hub failure of some kind. I don't see how that clip could fail.
Coastie Dory
Dealer
City/Region: St. Louis
State or Province: MO
PostPosted: Tue Oct 07, 2008 2:00 am    Post subject: Reply with quote
The plastic Mercury hubs do get loose from new and usually need to be tightened again. I have never seen one get so bad the tabs allowed the elastic nut to back off though. Perhaps someone was trying to remove it and was interrupted! At least you were lucky enough to get it back.
There are some very nice prop locks available to prevent this from happening again. They are cheap when compared to the price of a new prop or being stranded.
Best of luck,
Randy
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Tue Oct 07, 2008 3:45 am    Post subject: Reply with quote
Tom,
So it was your turn to put on "the show" at the Whittier dock last weekend. Glad you retrieved your prop.
It happened to me in Homer while driving a friends boat with an I/O. The nut backed off in Halibut Cove but the prop did not come off until stopping at the Homer Dock.
Jack on HIGH TIDE (parked for the winter)
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Post new topic   Reply to topic    The C-Brats Forum Index -> Propellers All times are GMT - 5 Hours
Page generation time: 0.0398s (PHP: 59% - SQL: 41%) - SQL queries: 25 - GZIP disabled - Debug on
