head odors
terraplane
City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Wed Aug 13, 2008 11:34 am    Post subject: head odors Reply with quote
Though i religiously pump out (every week) and use the holding tank very little...almost entirely urine.....there is a decided odor which occurs when i flush the head...a gassy odor.
I also fill the holding tank sometimes with fresh water and let it swish around for a day to clean sides of tank.
I use the standard West Marine holding tank stuff.
Suggestions?
terraplane
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Wed Aug 13, 2008 12:04 pm    Post subject: Re: head odors Reply with quote
Suggestions?
terraplane
Yikes...what you have done above is just what was suggested to me. Although I think it was Bad Boy who suggested the problem also lies in a small vent line.
Captain Matt
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Wed Aug 13, 2008 12:30 pm    Post subject: Reply with quote
If you are flushing with salt water it is almost always the flush water line. Stuff grows in the salt water intake line and as you flush you pump it into the head. Sulfur smell. If you go to boat brokers and look at the boats on the water and smell that smell in the head, that is usually what it is. West Marine, and others, used to sell a little kit that put a "T" in the intake line with a small bottle of treatment screwed to it that metered out as you flushed. I found that the best solution was just to flush a lot and keep the critters from taking up residence in the seawater line. Only exception was the one time a candlefish got sucked into the incoming line. Could not figure out why the flush was locked up.
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Wed Aug 13, 2008 1:37 pm    Post subject: Salt vs. Fresh Reply with quote
The salt water would definitely make stinky! I'm not aware of any C-Dory's that have a raw water intake for the flush. Unless they accidentally pour salt water into the fresh water holding tank or something.
Grumpy
City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
PostPosted: Wed Aug 13, 2008 1:39 pm    Post subject: Reply with quote
lloyds,
Never thought of that. I don't have the problem (yet) and I wonder if it is due to the fact that the thru-hull valve for the raw water intake is always open when I haul the boat and therefore the salt water drains out of it which I assume will kill any critters. Can't speak for other boat configurations but this might be a point for those who trailer to open the sea cock and drain the intake. (Don't try it with the drain )Disgust
Merv
Alasgun
Guest
PostPosted: Wed Aug 13, 2008 2:13 pm    Post subject: Head Odors Reply with quote
That's odd Matt as I don't know of a C-dory that does NOT use a raw water flush! Our 25 comes in the sea cock and either goes to the wash down or the head.
On to this stink thing, we boat exclusively in the salt, use the head for a lot more than urine and are very happy with the system. We learned early on how to stay happy with the system.
The only additive we like is the West Marine Mint version, the others contribute to their own funky smell.
As a trip comes to a close we will dump the tank (yep - in the ocean) and travel a ways with the sea cock handle open and the toilet valve in the wet bowl position. This will fill your holding tank with little or no effort and with a little practice you will figure it out. Pay attention to how full the bowl is and shut the sea cock if it gets close to the rim, only takes a second and the water is gone and you can open er up again. It's more a function of speed and we find that at 18 knts everything works fine.
Fill that holding tank and slosh er a bit before dumping it again (in the ocean). We do this twice before taking the boat out and once home I do the same thing twice with fresh water. The last time I leave the tank full and add 2 oz of the mint stuff and just leave the thing sit full till the next trip. Lack of oxygen prevents funny growth!. Ive been using this method for the last 3 years and I would chalange anyone to smell my head!
It's a lot simpler than most folks make it.
Mike
lloyds
PostPosted: Wed Aug 13, 2008 2:16 pm    Post subject: Reply with quote
Probably not a problem on trailered boats because all the water in the line does drain out. But a definite problem for any boat left in the water for more than a few weeks that flushes with raw water, and doesn't get flushed often. If I left one of my boats for a couple weeks, when I got back and flushed it smelled. I had to flush a lot to get rid of it.
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Wed Aug 13, 2008 3:33 pm    Post subject: Re: Head Odors Reply with quote
Alasgun wrote:
That's odd Matt as I don't know of a C-dory that does NOT use a raw water flush! ....
Mike
Wild....on my Tomcat the water for the flush comes from the fresh water holding tank. The only raw water intake I have is for the washdown pump in the cockpit. I thought I saw the same setup on the C-25's I looked at.
GxK
City/Region: Frenchman's Bay, Lake Ontario
State or Province: ON
C-Dory Model: 24 Tomcat
Vessel Name: At Last! ex Goose
PostPosted: Wed Aug 13, 2008 4:06 pm    Post subject: Re: Head Odors Reply with quote
matt_unique wrote:
Mike
Hmmm . . . I guess there is no consistency in the C-Dory family. On my TomCat, the head flushes with seawater while the galley and washdown are fed from the freshwater tank.
--Georgs
Georgs Kolesnikovs
TomCat 24 At Last!
Puffin Saco 12 Finally!
http://tomcat-tales.blogspot.com/
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Wed Aug 13, 2008 4:54 pm    Post subject: Re: Head Odors Reply with quote
GxK wrote:
matt_unique wrote:
Mike
--Georgs
Interesting...I was reading an older thread where someone else mentioned their washdown was plumbed to the fresh water holding tank.
I assume they installed a valve for your flush intake similar to what I have for the washdown?
PostPosted: Wed Aug 13, 2008 4:58 pm    Post subject: Reply with quote
Tom, my friend, that question is what is known in boxing circles as "leading with your jaw"! There is a one word answer: AIRHEAD!!!!
Page generation time: 0.0297s (PHP: 77% - SQL: 23%) - SQL queries: 27 - GZIP disabled - Debug on
