gary allen
Joined: 27 Jul 2004 Posts: 41 City/Region: Santa Rosa
Vessel Name: Rosy B
Posted: Tue Jul 01, 2008 11:57 am Post subject: tilt gauge not functioning |
I have twin Honda 50s and noticed yesterday that the port tilt (showing the position of the motor) gauge is not working. Most likely due to a bad connection at the battery?
Thanks for the help. |
Tad and Toby Jackson
Joined: 08 Aug 2007 Posts: 135 City/Region: Merritt Island
Vessel Name: Comfy Dory
Photos: Comfy Dory
Posted: Tue Jul 01, 2008 1:19 pm Post subject: |
Gary,
On my Honda 75, I had the same problem. The plastic spring loaded bracket that is between the engine and the mounting bracket has a tendency to bind up over time. I just used some WD 40 on it to free it up and the gauge then read correctly.
Tad |
colobear
Photos: C-Cakes
Posted: Tue Jul 01, 2008 5:31 pm Post subject: |
I had the same problem on my twin 40's. Tilt the engine all the way up, then look to the left of the hydraulic shaft and you should see about a 3" long black plastic arm with a spring around it's base. That is the tilt sensor arm. Les Lampman explained all this to me and told me to lubricate that area frequently. I do...problem solved. _________________ Patti and Barry
formerly C-Cakes, now
rving around N. America |
gary allen
Vessel Name: Rosy B
Posted: Wed Jul 02, 2008 11:18 am Post subject: |
Thanks for the replies. I'll check for that spring when I go to the marina tomorrow.
Gary |
