YACD
Joined: 14 Sep 2007 Posts: 74 City/Region: Middle River, Chesapeake Bay
State or Province: MD
Photos: F. Silvestris
Posted: Mon Jun 02, 2008 6:08 pm Post subject: 2 stroke outboards |
Does anyone have experience with outboards from
http://www.smalloutboardengines.com/index.html
Their 2/2.5hp engines are light (20#), cheap ($500) and very easy to maintain. They are low emission engines as measured by meeting the EPA CARB Tier 2 EPA standard. Their return policy is very easy to understand: returns not accepted - period  |
CW
Vessel Name: Satisfaction
Posted: Mon Jun 02, 2008 7:12 pm Post subject: |
It looks like a weedeater with a prop... If it is a Stihl engine, I bet it would work great on a light inflatable or dinghy. I know the use of weedeater engines has also revolutionized the cost of remote controlled model airplanes. C.W. _________________ "The West is the Best... Just get here and we'll do the rest." Jim Morrison |
C-Nile
Joined: 09 May 2008 Posts: 638 City/Region: Connecticut
State or Province: CT
C-Dory Year: 2012
Vessel Name: Betty Ann
Photos: C-Nile
Posted: Mon Jun 02, 2008 9:05 pm Post subject: |
YACD: I was in Cabelas yesterday, and was looking at a 2.5 pound, $650 water cooled Suzuki 4-stroke outboard that was only 29 pounds! The problem with air cooled motors is that may overheat in temperatures above 90 degrees F. Another consideration is noise. What is the DB output of the motor at full throttle? If it is like a weed whacker, it could be quite loud. What about reliability over the long haul? I'd put my money on the 4-stroke.
Rich |
YACD
Adeline
Joined: 03 Nov 2003 Posts: 985 City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
Posted: Mon Jun 02, 2008 10:08 pm Post subject: |
Here is what $350 can buy on Craig's List. 1999 Johnson 4hp-Twin Cylinders-Twist Grip Throttle-F/N-Emergency Cut Off-33#s-Used Twice. This one is mine and isn't for sale. Other gems are out there if you're patient. _________________ Pete
Valkyrie
Joined: 09 Jan 2005 Posts: 1028 City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
Posted: Mon Jun 02, 2008 10:37 pm Post subject: |
Weedeater with a prop is right. Years ago (like 25) a company that made made weedeaters came out with a small line of lightweight 2 stroke outboards that they called Cruise N' Carry.
I had a 2.7 horse model that weight 12 pounds and 7 ounces. It had lots of torque and ran like a champ on my Achilles and canoe, albeit loudly as it was air-cooled. I ran it for about 15 years with no problem.
Nick
"Valkyrie" |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Mon Jun 02, 2008 11:19 pm Post subject: |
Actually, you can take it back if it is in within 30 days and you have not used it. At least that is what I read in the later nomenclature. It looks kinda cool. But, it also looks a little fragile in design. As someone mentioned, it seems to look more suitable for light lawn duties than marine usage. However, my weed eater is really tough.....it just might surprise a guy what it could do. |
Posted: Mon Jun 02, 2008 11:53 pm Post subject: |
Wow, another Curse n' Tarry (aka Cruise N' Carry) owner. I thought that was the neatest motor ever. Started out on a Sevlour (sic). We must of been the only ones with one of those cheap inflatables with a motor mount. Then used it on an Avon inflatable when we had a 25' sailboat. Small and light, WITH a neutral. You could start it without ramming something.
Finally outgrew it, and gave it to a missionary who took it to Africa, in the Congo. Left it there when they evacuated in a hurry. Hope someone is making use of it.
Upgraded to a 3 hp Johnson twin, also mentioned above. That one went through Mexico, the So Pac and Alaska. Way better than the Oriental brands, and just as cheap. Couldn't figure out why they weren't more popular. Made in Belgium, so OMC could import their bigger motors there.
Boris |
T.R. Bauer
Posted: Tue Jun 03, 2008 3:09 am Post subject: |
journey on wrote: | Wow, another Curse n' Tarry (aka Cruise N' Carry) owner. I thought that was the neatest motor ever. Started out on a Sevlour (sic). We must of been the only ones with one of those cheap inflatables with a motor mount. Then used it on an Avon inflatable when we had a 25' sailboat. Small and light, WITH a neutral. You could start it without ramming something.
Boris |
The best, and by far, trolling motor I have ever had (I still have it) is a 6hp Envinrude twin. It runs smooth as silk, relatively clean, doesn't vibrate to beat hell, and starts like a dream. I agree; those little twin motors are great! |
Posted: Tue Jun 03, 2008 4:55 am Post subject: |
T.R. Bauer wrote: |
Agree! If you can stand the slightly larger weight and size, a very small water cooled twin beats the heck out of a single cylinder air cooled motor every time! Plus with the twin you get a real gear shift, not a pivoting motor (360 degree reverse) motor without a shift or clutch. A two stroke is fine if you take good care of it and know how to keep it running lean so it won't load up when trolling.
matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Tue Jun 03, 2008 8:11 am Post subject: 2-stroke |
I use a 2003, 3.5 hp Merc 2 stroke water cooled on my small inflatable dinghy. It's a single cylinder, and unfortunately not very environmentally friendly, but I burn just 1-gal of gas the entire season. I bought it brand new in 2004 (leftover special). I use it to get back and forth between the dock and my mooring and for island excursions. It's relatively light, as I recall about 29 lbs.
The next time I need one I will go 4-stroke just to be a bit better on the environment. _________________ Captain Matt
Posted: Tue Jun 03, 2008 10:18 am Post subject: |
T. R. Bauer;
I didn't mention it, but I got rid of the 3 hp Johnson for a 6 hp Johnson whilst we were touring the west coast of Florida. That, sir, is the best motor I've ever owned. Still have it. Unfortunately, it isn't big enough to serve as a back-up on the 25, so it just sits. Can plane a 10" inflatable with 2 in it, it's light, and uses about the same gas as the 4-stroke Honda.
Got a great deal on it (new) in Sarasota, Fl. Next week I read that OMC was going bankrupt. Thank heavens, never needed any service. Suppose I'll have to sell it, but it's a great motor.
Boris |
Wefings Dealer
Joined: 29 Nov 2005 Posts: 2086 City/Region: Panhandle
Photos: Cruise Ship #4
Posted: Tue Jun 03, 2008 2:14 pm Post subject: |
Matt, are you sure thats not a 3.3 Mercury ?? I just got one too . Its really a Tohatsu in Merc clothing . Great little 2 stroke .
Marc _________________ Wefings Marine Website
Since 1909 |
CW
Posted: Tue Jun 03, 2008 7:23 pm Post subject: |
I know, it is a skosh heavier etc. but I got a great used Johnson 7.5 horse 2-stroke (1980s version) that had bright yellow, unstained foam inside the cowling indicating near-new condition for $569. It runs great, trolls great and can (unlike a 6 hp) get my 12 ft. aluminum Mirrocraft duck boat up on a plane with two guys, a dog and gear. Extremely reliable. C.W. |
Joined: 02 Nov 2003 Posts: 21383 City/Region: Pensacola
Posted: Wed Jun 04, 2008 12:36 pm Post subject: |
Marc,
At one time Merc made (rebadged as you say) both a 3.3 and 3.5. As I recollect one had the shift to neutral, the other no shift.
I have one of the Suzuki 2.5 hp 29 lb 4 strokes (from Wefings)--and it works fine.. For dinghy motors is is as close as the 2 strokes in lightness and ease to handle.
Not all loved the "cruise and carry" engines. I would be very leary of the "weed eater" type of outboards. They are not made for salt water. Corrorsion will be a major factor, as will service. Also there is no substitute for displacement and torque in pushing a dinghy. 1.5 to 2 hp is marginal at the best if you get caught in a real blow in an inflatable.....you may not be able to make headway against the wind and waves....
I agree that mid 80's to early 90's OMC outboards were outstanding. I had one of the 4.5 hp 2 strokes and had several thousand hours on it--still running like a top when I sold it. _________________ Bob Austin
