cleats,fenders and tying up
BaseCampAnne
City/Region: San Diego/Anacortes
Vessel Name: SEA COASTER
Photos: SEA COASTER
PostPosted: Tue Apr 01, 2008 11:48 am    Post subject: cleats,fenders and tying up Reply with quote
I have been experimenting with my 22' and wonder where others place the fender lines on the middle (widest) section of our boats? It seems to me that the cleat is too low to be of use with many docks so I am guessing that most folks tie off from the grab rails on top of the boat, correct?
Thanks, Anne
Wayne McCown
City/Region: Rochester
State or Province: NY
Vessel Name: Little Mac
Photos: Little Mac
PostPosted: Tue Apr 01, 2008 12:29 pm    Post subject: Reply with quote
Most of the time I am able to use the cleats. A couple of times--at a high dock--I have had to tie off the grab rail.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Apr 01, 2008 1:48 pm    Post subject: Reply with quote
I found a fender line and plastic clip at West Marine that allows me to open the window and reach up and clip the line to the cabin handrail, all without having to go forward or outside. Works well for me and gets the fender right where it needs to be without cluttering up my cleats.
Doryman
M/V Lori Ann
Anacortes, WA
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Tue Apr 01, 2008 2:08 pm    Post subject: Reply with quote
Anne,
I installed small brackets just outside the forward sliding windows on C-Cakes and at the rear of the outside cabin wall (See C-Cakes album photo #10). With these Patti and I can just open the window and put the fender out onto the forward bracket and the stern fender is easily attached to the rear bracket. I made the fender lines (whips) the right length so they are interchangeable and added a loop so we can put a third fender over the aft cleat when we feel the need. This has been very satisfactory, quick and easy.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Tue Apr 01, 2008 5:02 pm    Post subject: Reply with quote
We put in the fold down pad eyes where necessary. Since these are thru bolted, they are strong enough for temporary mooring as well as fenders.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Apr 01, 2008 9:36 pm    Post subject: Reply with quote
I think tying off to the grabrails is just tempting fate. I use the cleats, no matter what. You never know when someone will throw a huge wake at you or the wind might come up while you are away a short distance.
Doryman
Photos: Lori Ann
PostPosted: Tue Apr 01, 2008 9:53 pm    Post subject: Reply with quote
Not sure I understand the issue you are concerned about. A wake could throw the fender on the deck, regardless of where it was tied off. Or are you envisioning a different scenario?
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Tue Apr 01, 2008 10:20 pm    Post subject: Reply with quote
These little Perko fender hooks about armslength outside the window (part#1246DP0CHR0)
MartyP
PostPosted: Wed Apr 02, 2008 1:46 am    Post subject: Fenders through the window Reply with quote
I just don't like to carry the fender, which may be damp, or dripping wet, through the window, over the electronics, and out the aft cabin door. Thought I had it figured out, with a small diameter line running from the bottom of the fender, I could pull it up from the cockpit onto the deck/step alongside the cabin, and loop the end of the pull line over the rod holder, and it was quick and easy to deploy or haul. Worked great all last season. then we put the boat name on, and wallaah, the fender comes up right where the boat name is, and 1. hides it on the stbd side; 2. rubs on the vinyl lettering while under way, threatening to eventually wear through the letters ; and now needs another place to live when it isn't hanging down and protecting SleepyC or dragging in the water and making a big splash.
I tried swinging it forward, and can do, but then it impedes the starbd running lite. Not an issue in the daytime, but if it gets a new home I want it to work every time.
I'm open to ideas, and thanks,
lloyds
PostPosted: Wed Apr 02, 2008 10:02 am    Post subject: Reply with quote
There are a lot of docks that have shallow overhangs and a lot of us use the taylor fenders. They can hang up under the overhangs if the timing is right. When it happens something has to give. The newer docks that are concrete and such don't have those but there are a lot of docks around puget sound that are old and wood and have overhangs to varying degrees. Even if the boat is tossed against a vertical float and pinches the fender on the way up it would be hard on a handhold.
Doryman
Photos: Lori Ann
PostPosted: Wed Apr 02, 2008 1:24 pm    Post subject: Reply with quote
Gotcha. Definitely a concern.
Dunno if this is relevant to that issue at all, but the trainer I hired to help me get started with the TC suggested that I put stainless steel washers on the fender whip above and below the fender itself. Supposed to provide more weight to help keep it in place. Anyone doing this?
Frogpawg
City/Region: Wallis Run; Montoursville, PA
Vessel Name: Soapy Joe
Photos: Soapy Joe
PostPosted: Wed Apr 02, 2008 8:02 pm    Post subject: Reply with quote
This fender clip has worked very well for me and as stated in some above posts, this type can be accessed from the window which is extremely handy.
Soapy Joe
22' Cruiser
Doryman
Photos: Lori Ann
PostPosted: Wed Apr 02, 2008 8:58 pm    Post subject: Reply with quote
Is THIS the fender clip you use?
Frogpawg
Photos: Soapy Joe
PostPosted: Wed Apr 02, 2008 9:00 pm    Post subject: Reply with quote
Yes Warren, that's it. You can see the pic much better/up close in my photo album.
Soapy Joe
22' Cruiser
Doryman
Photos: Lori Ann
PostPosted: Wed Apr 02, 2008 9:01 pm    Post subject: Reply with quote
Do you tie a loop in your fender whip for this hook?
Page generation time: 0.0868s (PHP: 54% - SQL: 46%) - SQL queries: 32 - GZIP disabled - Debug on
