led anchor light
mwilson
City/Region: missoula
State or Province: MT
Vessel Name: STORMY
PostPosted: Wed Mar 26, 2008 11:16 am    Post subject: led anchor light Reply with quote
Anyone know of a source for a led anchor light that would replace the one that comes with the 22 cruiser? Bulb or the post. I'm thinking the lower power drain on the hook would be worth the investment.
michael
Sarge
City/Region: Edmonds
Vessel Name: Sea Badger
Photos: Gigi
PostPosted: Wed Mar 26, 2008 12:49 pm    Post subject: Reply with quote
Michael,
Are you talking about something like this?
http://www.svhotwire.com/ogm_lx_led_anchor_light.html
-Sarge
2001 2150 Bayliner, sold
2007 CD25, sold
2007 Harbercraft Kingfisher 2850, sold
2011 Stabicraft 2250SC, sold
2011 Eastern 18cc
Blog: http://theseabadger.wordpress.com
View user's profile Send private message Visit poster's website AIM Address
Valkyrie
City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
PostPosted: Wed Mar 26, 2008 1:00 pm    Post subject: Reply with quote
If I am not mistaken, this question has come up a few times before and no one, to my knowledge, has found a direct LED replacement for the anchor light. I have ordered a few that were "supposed" to fit, but had to send them back.
One way to save power while running an anchor light is to buy the Mega Utility Light from Davis Instruments, which only draws a tenth of an amp per hour, comes with a long cord and plugs into the 12 volt outlet. I have attached mine to a short piece of PVC which slides onto my radar arch-mounted VHF antenna, which gets it up over all of the stuff up there. We run the cord through the helm window.
This light can also be used in the cockpit by hanging it from the bimini. It works well and will do until I can find an LED replacement light for our anchor light.
Nick
"Valkyrie"
IT-SEA-BIT-C
Guest
PostPosted: Wed Mar 26, 2008 1:03 pm    Post subject: Reply with quote
it's not LED but they make cheap battery powered ones , no draw on batteries . west marine and pretty much everyone carries them .
PostPosted: Wed Mar 26, 2008 1:07 pm    Post subject: Reply with quote
well, Sarge, I finally noticed that you are now a Harbercraft owner. I looked at those boats, and thought they were great aluminum boats. Unfortunately they didn't build a cruiser AND they weren't cheap. I think they were lighter than the C-Dory. Is yours trailerabel, and what kind of engines did you get? If you've described this elsewhere, just let me know.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Wed Mar 26, 2008 1:39 pm    Post subject: Reply with quote
You can simply replace the incandescent bulb in your present light with an LED bulb. Here is one source: www.SailorSams.com Try boat LED light bulbs for your search term.
Patti and Barry
formerly C-Cakes, now
rving around N. America
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Wed Mar 26, 2008 2:12 pm    Post subject: Reply with quote
Here is another options for bulbs. About half way down the page are 15 LED bulbs of type BA15d for $9.99 each. Based on the specs, it seems like they could be used in the anchor light or the interior lights. I have not tried them yet, but I plan to. I inquired about some other taller bulbs for the anchor light, but I think they are too large to fit into the anchor light.
Rob
http://autolumination.com/otherleds.htm
Sarge
Photos: Gigi
PostPosted: Wed Mar 26, 2008 2:46 pm    Post subject: Reply with quote
Boris,
A lot of your questions are answered in this thread:
http://www.c-brats.com/viewtopic.php?t=8457
In addition:
Dry my boat weighs 5000 lbs, which is 1000 lbs less than the TomCat. Not bad considering that it is 28' long (loa is ~31.5') and has a beam of 9'6".
I have dual Mercury Verado 150s, top speed ~45 mph.
If you look on the other thread and click on the factory link you'll see that she is set up very much like a CD 25.
jstates
City/Region: SHELTON
Vessel Name: Endurance
Photos: Endurance
PostPosted: Wed Mar 26, 2008 11:56 pm    Post subject: LED anchor light replacement for 22 Reply with quote
LED anchor light
I bought one light bulb replacement - I think a Series 25? at SBS from Fisheries Supply - had to flatten out the wires where they attached to light fixture inside - bulb just barely fits.
It is very bright and about $40 - from Dr. LED .
I don't have the part number - but Dr LED can probably come up with the part number if you have the details on your current bulb.
Jim on Endurance
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Thu Mar 27, 2008 12:42 am    Post subject: Reply with quote
might try something like ebay item 130208361453 . i bought one of these and intend to fab a base to fit it from a std. auto base. (delivered for under 20 bucks, 3.1 watts). unfortunately my current anchor mast uses 2 bulbs of a diff type, but shouldn't be hard to modify.
chris
mathias999us
City/Region: Forest Lake
State or Province: MN
Vessel Name: Venture Bound
Photos: Venture Bound
PostPosted: Sat May 23, 2015 7:26 pm    Post subject: Reply with quote
Beware, I put led bulbs in my perko fold down anchor light, and it caused severe interference with the VHF reception. Others could hear me, but incoming was completely garbled. Here are the type that I used:
http://www.amazon.com/Cutequeen-Lumens-Festoon-DE3175-DE3021/dp/B00NBHHVGU/ref=sr_1_1?ie=UTF8&qid=1432423568&sr=8-1&keywords=31mm+festoon+led
PostPosted: Sat May 23, 2015 8:03 pm    Post subject: Reply with quote
Long term known problem. FCC Part 15 rule deals with this, It is usually in the circuit for the light (in the bulb in this case, not the LED itself).
I would start by putting ferrite beads on the power supply of the Light--it should be as close to the light as possible. You can go with ferrite beads on the VHF lead, and VHF power supply. There are also filters you can put on the VHF power supply. I don't know if I have any I'm my ham junk box or not.
If the Bulb is up to FCC 15 standards, it should not--this means that the bulb is not tested. I have an LED dedicated light, I put on the Radar Dome strut, and no issues.
Hope that helps…or not. You can find LED bulbs which won't…but it may be happen chance.
mathias999us
PostPosted: Sat May 23, 2015 8:18 pm    Post subject: Reply with quote
Thanks Bob - For now I've decided to try to replace the fold-down anchor light with a new Perko unit that was designed with LED. I found one that I believe has the same base pattern so it should in theory be a drop-in fit. I can't find any info on its compliance with FCC 15 but I also cannot find anyone complaining about it interfering with VHF, and it is designed for marine applications. I also found a website that claimed to have tested this light for interference with no issues:
http://www.boatingmag.com/gear/boatinglab-tests-led-lights
The unit I ordered was the Perko 1636DP0CHR as seen here in the perko catalog:
http://www.perko.com/catalog/navigation_lights_under_20_meters/814/stealth_series_-_led_fold_down_white_all-round_light/
I'll report back after I install and test it.
I assume that a good test is to tune to a weak weather station, and turn the lights off and on to detect any changes in the signal.
I've done this with all the cabin lights in my boat and the red/greens, and the only one that gave me trouble is the fold-down all white.
PostPosted: Sat May 23, 2015 9:49 pm    Post subject: Reply with quote
That should work well. Too bad that some manufactures don't follow the guide lines. Generally the product is less expensive, but don't count on that!
PostPosted: Sat May 23, 2015 10:23 pm    Post subject: Reply with quote
I found a LED light that went in my Perko anchor light. Fit fine and very bright. Does not cause interference on the radio as far as I can tell.
http://store.marinebeam.com/replacement-for-ge89-and-ge90-attwood-perko-bayonets/
$15 plus shipping.
If your socket is corroded it can be a little tricky to put this in because there is little to grip but the LED assembly itself.
Page generation time: 0.1132s (PHP: 86% - SQL: 14%) - SQL queries: 32 - GZIP disabled - Debug on
