siezed windows
serenitymay1995
City/Region: Cumberland
Vessel Name: Gumption
PostPosted: Wed Mar 12, 2008 9:42 pm    Post subject: siezed windows Reply with quote
our new used 22 cruiser has sat for over a year before we got her. the windows are seized up tight and i have applied some silicone to the track and the rubber seal and still no movement. should i pry the rubber seal open or ?
PostPosted: Wed Mar 12, 2008 10:46 pm    Post subject: Reply with quote
It's likely that they were closed while they still had some salt on 'em. Before you pry anything, try this: put ample amounts of warm fresh water all around the window, especially along the track. Then try opening the window with TWO people: one on the inside (holding the latch open and pulling) and one on the outside, pushing back on the window. When our windows have stuck shut, this has always worked for us. Then, clean the tracks, move the window and clean in front and behind it. When the fuzzy stuff in the track dries, get some Liquid Rollers and spray it liberally in the tracks and "work it" back and forth.
I have read on here that some have widened the widow tracks slightly, but the chance of leakage concerns me with that.
Hope that helps - keep us posted.
PostPosted: Thu Mar 13, 2008 9:47 am    Post subject: Reply with quote
Used to happen to me all the time on Capt's Choice. I kept a small, nubby flat screwdriver at the helm and when they stuck, held the latch open with one hand and put the blade between the latch and the window casing and pried (gently). Worked every time. When you do get it open, use liquid rollers or silicone or the like on the tracks.
serenitymay1995
PostPosted: Thu Mar 13, 2008 10:23 pm    Post subject: Reply with quote
thanks guys i will try both options suggested. once they are freed up i will use silicone frequently. heading up to quatsino sound for early halibut march 29 - april 1.
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Thu Mar 13, 2008 11:26 pm    Post subject: Reply with quote
Another suggestion: take a 4-6" flexible blade drywall knife(trowel) and carefully work it down with a gentle side to side rocking pressure between the exterior glass and the grey fuzzy liner material, along the entire bottom length of the opening window. Likely the inside is OK and that crap has formed in the outside crevice and bonded the window shut. Once it's moving you can clean the crevice out with running water and a toothbrush or other small crevice brush. Make sure the weep holes in the aluminum extrusion are clean and confirm that water flows through them. don't apply lubricant until the gasket material is completely clean and dry. Don't use a heat gun to dry the gasket material; let it air dry. Good luck! Mike.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Fri Mar 14, 2008 2:02 am    Post subject: Reply with quote
In the Pacific Northwest?..... Rolling Eyes
Dave S.
"Sea Shift"
C-Brat #16
smittypaddler
City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
PostPosted: Fri Mar 14, 2008 9:09 am    Post subject: simple suggestion Reply with quote
This may be too simple, but on my 22-cruiser, I have to push the window slightly forward before it will unlatch and open. If yours work similarly, it may not be obvious if you've never tried to open the windows.
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Fri Mar 14, 2008 10:49 pm    Post subject: Reply with quote
i've found on my old 87 that pushing up and back on the sliding portion with flat hands seems to raise the window and loosen the resistance in the lower track. once it's open a bit lift on the open side, flat on the other to open. once open, you can work on cleaning out the track.
i had to replace a driver side cracked window and found that plastic bottom runner pretty much uv'd to death, very brittle. replaced with "L" aluminum mirror frame from the glass co. needed two layers, but
works great.
serenitymay1995
PostPosted: Sat Mar 15, 2008 12:40 am    Post subject: Reply with quote
we got the windows sliding again, washed out the track and scrubbed it with hot water and dish soap then slid a small scraper between the inner rubber and the window. had to push handle forwards to realease the latch, will lube her up good after it all dries. sometime in august Laughing it only rains twice a year here. once for 5 months and once for 6 months thanks for the help.
serenitymay1995
PostPosted: Sat Mar 15, 2008 12:41 am    Post subject: Reply with quote
timflan
Photos: Two Lucky Fish
PostPosted: Sun Mar 16, 2008 12:32 am    Post subject: Reply with quote
Glad you got 'em moving. Be sure to read this thread:
http://www.c-brats.com/viewtopic.php?t=4940&highlight=window+jammed
Timothy R. R. Flanagan
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sat Jun 07, 2008 10:40 pm    Post subject: Window Reply with quote
My starboard side Captains window has been seized since I owned it. I finally got around to fixing it today. I sprayed WD-40 around the seams (top and bottom), used a screw driver to carefully pry the rubber away from the window (basically to jostle it a bit), and it opened right up. It now moves easier than the rest of my windows. Next time out I will shoot a little WD-40 around all of them and open/close them several times to work it in.
So...the advice given by others above works!
Captain Matt
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Jun 08, 2008 2:20 am    Post subject: Reply with quote
Matt,
Many of us are now using Liquid Rollers available at WM for our window slides, haven't tried it yet but the reports are glowing.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Alasgun
Guest
PostPosted: Sun Jun 08, 2008 9:28 am    Post subject: Siezed WIndow Reply with quote
Id be a little leary of using the WD40 as it has an affinity to"creep". In time it will find it's way out the drains and down the side of you cabin! Along the way it will be a dirt magnet that may make the problem worse in time.
Stick with the afore mentioned lubes which will dry and you will be better off.
Mike
Lucky Day
City/Region: Churchton
State or Province: MD
Vessel Name: Lucky Day
Photos: Lucky Day
PostPosted: Sun Jun 08, 2008 11:36 am    Post subject: Reply with quote
I've used Liquid Rollers on all the sliding windows. It works great. I applied two months ago and all the windows are still sliding like they should.
Page generation time: 0.0514s (PHP: 68% - SQL: 32%) - SQL queries: 31 - GZIP disabled - Debug on
