cleaning fuel tanks
Goto page 1, 2, 3  Next
blackfish
City/Region: saltair
Vessel Name: raincoast
Photos: Raincoast
PostPosted: Sat Feb 23, 2008 6:25 pm    Post subject: cleaning fuel tanks Reply with quote
I'm having some problems with our honda 90
since we purchased our boat last Nov the motor has had a very bad hesitation to the point it will stall if you throttle up to fast (ANY RPM).
One of the carb floats was sticking so i had my mechanic clean the carbs
but unfortunately this did not solve the hesitation problem
so next i replaced the fuel filter , racor filter and fuel lines
still no good.
I've run the boat on a portable fuel tank and It runs great.
So this leaves me with the fuel tanks
my question;
is there a screen on the end of the fuel pickup line in the tank that could be clogged and how do go about removing the pickup line to inspect it
I've tryed turning the fitting with a wrench, where it enters the tank with no luck
thanks for any help
dogon dory
Vessel Name: DogOnDory
PostPosted: Sat Feb 23, 2008 6:33 pm    Post subject: Reply with quote
blackfish
Photos: Raincoast
PostPosted: Sat Feb 23, 2008 7:11 pm    Post subject: Reply with quote
problem is there when using either tank and at any fuel level ,sorry not sure if the bulb goes flat or not
PostPosted: Sat Feb 23, 2008 9:26 pm    Post subject: Reply with quote
I had a problem with one of the antisiphon valves of the Tom Cat 255 right out of the box. It took some experimentation to find out that the antisiphon valve was bad. C Dory sent me a new one. I used a straight hose barb to bypass the anti-siphon valve (I now carry a spare anti siphon valve).
Yes, there should be a screen on the pickup, but not guarantee that there is one. I would look at the bulb as Dan suggests. Also check to be sure that there is no air comming into the line. Most tanks will allow you to remove the fuel draw tube from the top--not sure about the 22's tanks.
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Sat Feb 23, 2008 11:09 pm    Post subject: Reply with quote
Blackfish:
I expect the problem is at least in part caused by bad fuel, but it's pretty easy to find out if that's the case, before you begin worrying about other components.
Here's what I suggest: fully empty one of your built-in tanks, either by siphoning out and transfering to the other built-in tank, or to your lawn mower, or, more pleasently, by doing a little boating. Then, confirm that you are still having the stall/hesitation problem on the built-in tank that has fuel remaining, and that the problem goes away when you switch over to the portable tank. Then, transfer the fuel from the portable, to the built-in tank which you emptied. Make sure you run the motor long enough to be burning the fuel which came from the portable, or drain the carbs and the racor, and see what happens.
If you want to run the test in reverse, empty the portable tank, fill it with fuel from one of the built-in tanks, and see how the motor performs on the portable.
It shouldn't take long to figure out the extent to which fuel is a factor.
Let us know, since this is a fairly common problem.
Good luck.
Alma's Only
2003 CD22 Cruiser with Honda 90
dogon dory
PostPosted: Sat Feb 23, 2008 11:47 pm    Post subject: Reply with quote
PostPosted: Sun Feb 24, 2008 12:11 am    Post subject: Reply with quote
With the spare hose, make sure you have a spare (new) quick connect that snaps/plugs into the motor. Old Raven Dave down here had fits because of a stupid little o-ring in the connector leaking air into the system. I got to tow him to port for it, though, so it wasn't a total loss.
dogon dory
PostPosted: Sun Feb 24, 2008 12:38 am    Post subject: Reply with quote
PostPosted: Sun Feb 24, 2008 1:13 am    Post subject: Reply with quote
Yeah, that's a Thumbs Up alright. But they had to do away with them on Suzukis because they suck more than Hondas. My '00 Honda still has the snap on gizmo, but maybe this gentleman's '04 doesn't.
blackfish
Photos: Raincoast
PostPosted: Sun Feb 24, 2008 2:22 am    Post subject: Reply with quote
Almas Only
I don't think bad fuel is the problem I've refilled both tanks at least twice since buying the boat and didn't seem to change anything.I also removed the old gas out of both tanks shortly after buying the boat in Nov.
dog on dory
I am also having a hard time believing both filler tubes are block
I have taken the fuel switch off and the fuel lines for inspection i'll replace the clamps and fuel lines at least I wont have to worry about any leaks in the near future
where is this anti-siphon valve located
and how would I go about checking it
thanks again for all the help
Almas Only
Photos: Alma's Only
PostPosted: Sun Feb 24, 2008 7:55 am    Post subject: Reply with quote
Blackfish:
I've frequently had the problem you describe with my Honda 90 on fresh fuel. I'm running smooth, then take on fuel, and within a little while, am having problems with hesitation/stalling upon acceleration. The motor starts, and otherwise runs fine, but will hesitate when I call for more power while underway, and occasionally stall when I try to power up from idle. Seems that a lot of fuel is "bad" as it goes into your tank, no matter how recently you bought it. If you have a fuel source which eliminates the problem (your portable tank), I urge you to use that same fuel to test other parts of your system, and confirm the extent to which the problems are related to fuel quality.
The other reason I've come to focus on fuel quality with a Honda 90, and only then look to other issues, is the manner in which the fuel is delivered.
If the motor runs fine at WOT, and doesn't flood when it is stopped and then restarted, it seems to me you can conclude the following:
1: There is fuel in all 4 carb bowls.
2: The fuel pumps work.
3: There is not a blockage in the fuel lines.
4: The fuel filters are not plugged or significantly restricted.
5: The fuel tank vents are not plugged.
6: The fuel quality is sufficient to allow ignition at high speed.
If your batteries remain healthy, then you can also conclude:
7: The batteries are capable of holding a charge, and of delivering current to the motor so it can start.
8: Something is charging the battery: either the alternator, shore power, or both. If you boat for any extended period of time, you know that the alternator is working.
I'm sure open to suggestions, corrections, or qualifications on these conclusions. But, if they stand, then you can also go a little farther.
If the fuel system is capable of keeping the carb bowls full at all throttle settings (idle to WOT), then any defects in that system, such as clogged filters, plugged tank vents, clogged or collapsed lines, leaking bulbs, etc., etc., are of no consequence. They might cause other problems, but not hesitation/stalling in the manner we're experiencing. It's a fuel delivery system, and if the components deliver fuel to the carb bowls, they are doing their job. They might be doing that job inefficiently, and therefore should be repaired/replaced, but the problems with motor performance with full carb bowls cannot, by definition, have anything to do with "upstream" components. If you have any doubts as to whether or not your system is capable of keeping the bowls full, just idle the motor, push the throttle forward, notice the hesitation/stall, and then turn the motor off, and drain all 4 carb float chambers. I've done this time and again, and they are always full. Therefore, I've concluded that my problem is not one of fuel availabliity.
I'd like to get some thoughts on what IS causing the problem, but since mine is affected by fuel quality, I'm pretty sure I need to focus on what's going on under the motor cover. I know I'm taking on fuel that's got alcohol it it, tends to accumulate water, etc. and that the problem comes and goes with different tankloads of fuel. I don't know what adjustments, if any, can be made to the Honda 90 to allow it to be less sensitive to fuel variations???????????????????????/
Alma's Only
Rick from Maine
City/Region: No. Berwick
State or Province: ME
Vessel Name: Hunky Dory
PostPosted: Sun Feb 24, 2008 8:33 am    Post subject: Reply with quote
Hi David,
You raise an interesting point. Can an engine be tuned to be less sensitive to the quality of the gas?
One way to investigate this fuel quality & hesitation would be to see if other Honda's with the same fuel as your boat had a problem.
We've cruised together and refueled at the same marinas. I don't recall that I've ever had a hesitation problem, though I've had flooded hot engine problems in past. Have you ever had the hesitation while on one of our cruises after we've refueled?
Rick from Maine
PostPosted: Sun Feb 24, 2008 12:42 pm    Post subject: Reply with quote
David-
The two things you haven't specifically checked yet (unless you've done as Dan suggests and by passed each component in the fuel delivery system one at a time with the extra hose) are the selector switch and the primer bulb.
The selector switch may be blocked, which would effect delivery all the time. (Mine rotates through six or more detent positions, not just the expected 3, and all but two of them are dry/shut off, so the valve is not a bulletproof component.)
The primer bulb could also be blocked, and it also is a single flow point/possible bottleneck in the system. There is an anti-siphon/check valve in the primer bulb which has given more than a few folks this kind of problem before. I'd just replace it or switch it with the one on the portable tank. Some have found that the primer bulb was installed backwards! There should be an arrow on the primer bulb which indicates the preferred direction of flow.
Just some more things to consider....
Good Luck! And keep us posted!
Holoholo
City/Region: Lincoln
PostPosted: Sun Feb 24, 2008 1:41 pm    Post subject: Reply with quote
I have a 2003 CD22 with twin 50 Yamahas and had the same issues of stalling and difficult starting. After having my mechanic go through both motors, the problem persisted and he finally checked both fuel tanks finding that the pickups (plastic) had disintegrated on one and cracked on the other. I ended up siphoning all the gas (about 35 gals total) on both then removing both tanks and painstakenly shaking out the remainders of both pickups. Then I changed all the fuel lines to 3/8 hose and the fuel connectors and primer balls to BOTH motors also making sure that the fuel switch was not plugged. Seems like the factory pickup was not the right material and should have been aluminum. This solved the problem completely.
Vern
PostPosted: Sun Feb 24, 2008 2:08 pm    Post subject: Reply with quote
Vern-
Good information! Always great to get BTDT (Ben There, Done That) feedback from one who's run the course. Much better than open-ended speculation!
Interesting that you have a 2003 CD-22 and David a 2004 CD-22....... same old story- the same defects in materials cause the same problems, a standard principle in trouble shooting.
That's one of the things that make this site such a valuable resource, being able to touch base with others that have had similar problems and found solutions.
Now if I could just find someone who could tell me how to get my wife to let me live on my boats about 300 days a year!
Joe. Laughing
Page 1 of 3
Page generation time: 0.0387s (PHP: 71% - SQL: 29%) - SQL queries: 32 - GZIP disabled - Debug on
