condensation
aknelson820
City/Region: bothell
Photos: aknelson820 (SeaSport, Name TBD)
PostPosted: Sat Aug 29, 2009 12:29 pm    Post subject: condensation Reply with quote
I seem to have a problem with condensation at night when sleeping on the boat. I have tried a fan having the hatch open and there moisture on the walls in the v-berth. any way to fight this. Rolling Eyes
2000 SeaSport 22
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Sat Aug 29, 2009 12:40 pm    Post subject: Reply with quote
Look up a material called Mascoat. Works great. There is quite a discussion on the site about it. I've had it on my 22 for 5 years.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
PostPosted: Sat Aug 29, 2009 3:07 pm    Post subject: Reply with quote
One of the "side effects" of living in WA. also gluing some foam to the overhead will help. I have used flexable closed cell PvC foam, and back packking paes, then cover with a perferated vinyl covering. Also a small air space and the vinyl. (Put 1/4" battons across, and glue or stape to those. The more air circulation, the less condensation.
PostPosted: Sat Aug 29, 2009 3:38 pm    Post subject: Reply with quote
We just got back from Vancouver Isle, etc. and for the first thyme we had condensation in the v-berth and in the cabin area bilge. This only happened when it rained, got cold and the boat was closed up. You haven't lived until you've tried to put on damp (but clean) underwear.
Clearly, the moisture in the air condensed when it met the cold outside hull, deck, and especially the metal of the hatch in the V-berth. Insulation will stop the heat transfer from inside to outside, and hopefully keep the moisture from condensing.
This leads me to the conclusion that it's not only necessary to insulate the overhead as Bob indicated, but it’s even more important to insulate the hull, especially when it’s below the waterline. Compared to other climes, the sea water in Canada is cold.
I have 2 choices: ¼’ cork 12x12 squares, or using the gallon of Mascoat in the garage. I’m choosing the latter. The V-berth is small enough, without using up more space.
PostPosted: Sat Aug 29, 2009 8:42 pm    Post subject: window is always open Reply with quote
We have rarely had moisture in the V-birth, maybe once. Procedure we use. Center window is always open, at least to the 1" or so where it can be "locked" open. The forward hatch cover is open the same, and the sliding window opposite the dock is open about 4 inches, unless it is raining. (Sure wish that C-dory would extend the roof out about another 2-3". Would make leaving the window open without water running off the roof and into the window possible.) The forward hatch and center window are OK to leave open in the manner posted, unless it is pounding rain.
In the morning, fire up the Wallas and warm the underwear first. The advantage of that is that it will also dry the cabin out Hot by the time the underwear, LJ's or ...... is warm.
SleepyC
PostPosted: Sat Aug 29, 2009 10:54 pm    Post subject: Reply with quote
First I agree with Boris, you have to insulate the hull as far down as you can get. You don't get much condensation, until it is high humidity: rain, cold etc. Also the hatch needs to be covered. We have "shades" over the tatch covers, and can put foam between the windshade and the hatch.
PostPosted: Sat Aug 29, 2009 10:58 pm    Post subject: Re: window is always open Reply with quote
SleepyC
Harvey-
I remember B~C making some cover-over / deflectors for the side sliding windows to keep the rain out while leaving them open.
Look through his album and / or PM him to get the photos and find the thread.
On Edit:
Here's the photos:
C-Dawg
City/Region: Spanaway
Photos: C-Dawg
PostPosted: Sat Aug 29, 2009 11:45 pm    Post subject: Re: condensation Reply with quote
Ask your local upholsterer about Monkey Fur. It's a synthetic pile fabric. We have it glued inside the V-berth.
Rick & Shirley
Go Dawgs!
C-Dawg sold November 2018
PostPosted: Sun Aug 30, 2009 12:31 am    Post subject: Reply with quote
I hate condensation/water inside the cabin, especially the V-berth. So, a couple of additional comments.
First, when it's raining outside, CLOSE ALL WINDOWS. We/I left a side window open in Lagoon Cove, tied up at the dock. When I got up in the morn to use the head, I stepped on wet carpet. Rain had come in the port side window, run down the side of the hull, through the back of the lazerette and soaked the beer carton, the rug, got the vacuum cleaner, etc. Took a couple of days to dry out.
Of course, closing the windows ensures that it becomes humid inside. .That's better than rain, I guess
Second, getting warm air from the Wallis to the V-berth in a C-25 is not an easy job. The Wallis heater fan blows right across the cabin, not forward. So, I use a heat driven Ecofan on the stove, to blow air towards the V-berth. The problem is to get enough heat into the V-berth and keeping it there long enough to do some good. That's where insulation helps, reducing the heat loss so the V-berth has a chance of keeping warm.
If you're tied up to the dock and connected to shore power, an electric heater sure helps.
I'm willing to stay in bed until the underwear dries, but Judy wants me up before noon. I'd rather keep it dry to begin with.
PostPosted: Sun Aug 30, 2009 1:09 am    Post subject: Reply with quote
Boris-
Please keep your powder dry! Your shorts, too!
A computer fan and a 3" corrugated tube can be used to route warm air form the heater vicinity to the v-berth or to wherever you want, but I'm not sure if your wife will think it kosher if it's hooked up to your shorts!
Joe. (It's Saturday night, OK?) Teeth Thumbs Up
PostPosted: Sun Aug 30, 2009 2:27 am    Post subject: tip on the window covers Reply with quote
Joe, Thanks for the tip on the window covers (B~C style). They do look good, and looks like they would certainly help. I will do some looking into his methods.
I didn't think about the difference in acreage between the 22 and 25. We do not have an Ecofan, but have considered them and if we find the right deal may go ahead with one. I know there are 2 types, 2 and 3 bladed. Most seem to have the 2, just wondering if it is the expense of the 3 or that it just does not do that much more for the extra expense.
Thanks Joe, this is truly a wonderful site, and you are an extra special asset here.
SleepyC
PostPosted: Sun Aug 30, 2009 9:59 am    Post subject: Reply with quote
We have tried the ECO fan vs just the Wallas fan. Generally we don't leave the Wallas on after we go to bed. But to heat the foreward cabin on the 25 (or any of the bunch) we use the "cheap O2 fan $11 from WalMart a couple of years ago, or the "endless breeze" higher end fan. that way you can really move some air in all parts of the boat.
Agree with Boris, that electric heat is great. We use the ceramic heater on low (can be powered with the EU 1000 Honda Generator if you wish). We used that to dry out some clothes on one really nasty day we had in AK this summer.
amy and karl
City/Region: Graham
Vessel Name: C-DAISY
Photos: C-DAISY
PostPosted: Sun Aug 30, 2009 11:08 am    Post subject: Condensation Reply with quote
We installed an Airtronic D2 by Espar about six months ago and are very pleased with the results. We wanted an alternative heat source should we have problems with our Wallas. We now only use the Wallas to cook with.
We took a two week trip up the discovery coast this summer and were very glad we had the Espar furnace. We had three days of straight rain and were able to dry our raincoats and other wet clothes fairly quickly. As far as condensation in the berth, we are able to turn the register so the hot air goes directly into the berth eliminating the condensation buildup.
Our register is located in the helm footlocker. From there with a rotating register you can heat the cabin or the berth. A gallon of diesel lasts about three days for us with nearly continuous use. We only wish this would have been an option when we ordered the boat.
Happy boating,
karl on C-Daisy
aknelson820
PostPosted: Sun Aug 30, 2009 12:29 pm    Post subject: Reply with quote
thanks guys, I now have some more ideas to try. we are going to Cornet Bay on sept 11 for 3 days so I will know then.
PostPosted: Sun Aug 30, 2009 12:30 pm    Post subject: Nice hot idea Reply with quote
Karl,
Nice hot idea and sounds really good. Do you have other photos of the Airtronic D2 by Espar and the installation? Curious how much space it is taking. Any chance the Wallas and Espar can use a common fuel tank? Have a link to previous discussion.
Maybe we can see it when you come up to Sequim (?) for the CBGT in a couple weeks.
Nice work and travel safe,
SleepyC
Page generation time: 0.0651s (PHP: 69% - SQL: 31%) - SQL queries: 32 - GZIP disabled - Debug on
